A couple months I re-routed my engine compartment wires and now my car won't start. I have spark, timing is set to 0. Now I had fuel pressure but after 10 tries, the fuel pump didn't prime and didn't have any fuel pressure. So I replaced the fuel pump relay and EEC relay but still nothing. I reset the Ertia switch and that didn't work. So I go back to the fuel pump relay, I checked it connected with a tester. The orange/light green wire has juice but the rest of the wires don't, even with the ignition on or off. Here is what I'm talking about:Fuel Pump Relay Diagram. Ain't I suppose to have power going to any other wires? Or did my fuel pump go out? or Is my computer fried? Thanx
By the way, This is on a 1989 GT 5-speed with a A9P computer.
Might also check the resistance (ohms) of the pink wire to see if it's just a bad wire.
