Stator sensor/ignition pickup/PIP module
  • Thread starter Thread starter Paul78Zephyr
  • Start date Start date Apr 11, 2007
P
Paul78Zephyr
14
Hudson, MA
Apr 11, 2007
  • Apr 11, 2007
Hi all,
Can anyone discuss the stator sensor/ignition pickup/PIP module that I believe is internal to the TFI distributor used on EFI. How difficult is it to replace (what is needed to get it out)? How often does it fail? I am actually going over all the major components of my EFI conversion and have never considered this component.
Thanks,
Paul
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 11, 2007
  • Apr 11, 2007
The PIP sensor sits in the bottom of the distributor under the shutter wheel. As the slots in the shutter wheel move past the PIP sensor, they uncover a magnet. The Hall effect sensor inside the PIP sensor sees the change in magnetic force and creates a pulse. This pulse is used to trigger the TFI when the SPOUT jumper is out. When the SPOUT jumper is in, the pulse is used by the computer to advance the timing and trigger the TFI. The PIP signal is also used by the computer to provide timing information for the fuel injectors.
A failing PIP will generate code 14. The failure symptoms often get worse as the PIP sensor heats up. Hard starting, misfire and poor performance are some of the problem symptoms.
You must press the distributor gear off the shaft to remove the distributor shaft and shutter wheel assembly. Once you have the distributor shaft/shutter wheel removed, there are two small screws that secure the PIP sensor in place. It works best to heat the distributor gear in an oven to 400 degrees or so to expand it so that it presses back on and lines up with the pin hole in the shaft.
Since pressing the gear off is a major pain, most guys just buy a remain distributor assembly.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Resolved 1989 Mustang GT no spark, no trigger pump relay
  • Nine Finger Wrenching
  • Nov 26, 2023
4K
Fox 5.0 Mustang Tech Nov 30, 2023
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
