steeda adjustable clutch quadrant
  • Thread starter Thread starter smellmygas
  • Start date Start date Mar 23, 2004
smellmygas
150
South Florida/Philly
Mar 23, 2004
  • Mar 23, 2004
i just got 1 of these today....its the double hook 1
just wondering how easy it is to install, and or if i can do it myself
please help or if there are any tech write ups that would be great
thanks
ss93cobra
1,422
Wilmington NC
Mar 23, 2004
  • Mar 23, 2004
Not too bad to do as long as you can fit under your dash. The biggest problem (and not a big deal) is removing the factory springs and quadrant pieces. Have a pick on hand to help pry the springs free. Basically, remove the two cotter pin stlye clips on the end of the factory shafts, remove the factory wound/coiled springs, slide the two plastic quadrant parts off, slide the new one on, hook the cable back up, put your pins/clips back in, and off you go. Don't be surprised to find out that you now need the adjustable cable or firewall adjuster though....
smellmygas
150
Mar 23, 2004
  • Mar 23, 2004
damn that sounds like a mission....i did get the adjustable cable with it too i forgot to mention.
any pics?
ss93cobra
1,422
Wilmington NC
Mar 23, 2004
  • Mar 23, 2004
Sorry, don't have the proper equipment to post pics, I spent my $ on the car. Anyway, the whole thing should take you about 30-45 minutes to do, including changing the cable. Too bad you live to far away, I'd give you a hand with it, done it several times on several cars. Really, once you start taking things off, it gets pretty self explanitory. One of those "oh yeah" moments. Give it a shot, worst case is you have to ask a question....
smellmygas
150
Mar 29, 2004
  • Mar 29, 2004
i jacked the car up today and took a few looks at my project at hand....im not sure how i get the cable out towards the clutch, do i have to engage the clutch or anything or do i just yank it...what is it attached to i see it goes in towards the tranny, i just dont see how i get it out.
any help??
J
jerry beach
2,671
Ocala,FL
Mar 29, 2004
  • Mar 29, 2004
There is one bolt holding the cover over it, then it slides back and off. Read the instructions that came with the kit and make sure you configure the ball shaped nut and lock nut properly on the clutch fork.
Some folks dont have any problems getting the stock quadrant off, but it took me darn near all day. I had to bend a metal brace for the dash slightly, then the factory pawl slid right off. It was easy after that. Take out you drvers seat before you start, and cover the studs with some thick padding. This will make the job much easier. The Haynes manual says to remove the pedal tree and lower the steering column, pay no attention to that. I strongly recommend a fire wall adj. too.
smellmygas
150
Mar 29, 2004
  • Mar 29, 2004
thanks i did get a firewall adjuster and adjustable cable
and i did not get instructions with it
J
jerry beach
2,671
Ocala,FL
Mar 30, 2004
  • Mar 30, 2004
Call up whoever made it or go to their web site and get the instructions. You will have to cut the bushing off the cable and use the FWA in its place.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
