Steeda Clutch Quadrant 82-04 & Adjust.Clutch Cable 79-04
Black Stampede
1,811
Grand Rapids, MI
*NEW* Steeda Double Hook Clutch Quadrant '82-'04 #555-7000
Product Details
The factory plastic self-adjusting quadrant is fine for stock clutches, but when you add a heavy duty clutch or some fast power-shifts, it starts to bend. This unwanted flex causes inconsistent clutch engagement and missed shifts at best, plus worn synchronizers and a broken quadrant at worst. Replace that weak plastic clutch quadrant with Steeda's super strong billet aluminum "Double Hook" quadrant. The strong flex free billet quadrant design stands up to the hardest shifts.
Steeda's exclusive Double Hook design lets you use your choice of an adjustable clutch cable or firewall mounted cable adjuster. Or use both together for the ultimate adjustment versatility. With other quadrants you are locked into one type of adjustment mechanism. With Steeda's Double Hook Quadrant, the choice is yours!
Fits Vehicle Model:
Ford Mustang
Fits Model Year:
1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
*NEW* Steeda Adjustable Clutch Cable '79-'04 #172-0000
Product Details
All Steeda clutch cables features a stainless steel inner cable and low friction Teflon lining, along with a high-durometer bushing at the firewall for improved clutch response and cable life. This bushing is much more durable and will not prematurely split and fail like lesser bushings. Steeda is the only company with these features, making this the finest quality clutch cable you can get for your Mustang.
Steeda's stainless steel cable will not allow the cable to rust through and is more durable, unlike all other cables on the market that are made from lesser quality galvanized steel.
Clutch adjustment can be adjusted by turning a nut at the end of the cable when the cable is used in combination with the required Steeda’s aluminum quadrant.
Fits Vehicle Model:
Ford Mustang V8, GT, Bullitt, Cobra
Fits Model Year:
1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
$70.00 SHIPPED
