  • SN95 4.6L Mustang Tech
steeda timing adjuster
  • Thread starter Thread starter rrl
  • Start date Start date Sep 20, 2005
R
rrl
92
  • Sep 20, 2005
i was thinking of getting a timing adjuster for my 02gt but can someone tell me how you adjust the timing with these.from pictures i've seen,they don't look like they are difficult to install.i only want to bump it up to 13 or 14 degrees and hope it runs good with 91 or 92 octane.any info regarding this would be welcomed.thanks!
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Sep 20, 2005
  • Sep 20, 2005
Have you checked out the stickies in this subforum yet?
If not, there are some great tips in there about timing adjusters.
http://forums.stangnet.com/showthread.php?t=246291
sgarlic
3,085
Sep 20, 2005
  • Sep 20, 2005
I believe with the steeda adjuster, there are allen head screws you loosen, then turn the adjuster to where you want it set, then re-tighten the allen head bolts and you're set. Somebody should chime in....
98stangv8
1,036
fayetteville, nc
Sep 20, 2005
  • Sep 20, 2005
yep...allan wrench...takes all of about 2 minutes to adjust...and it only takes that long because you have to maneuver around the hot water radiator pipe on the top...if the car is cold, takes about 20 seconds...very easy to do!
53BigDog
2,331
Palm Harbor, FL
Sep 21, 2005
  • Sep 21, 2005
Yep what he said. Also the hardest part is the light cranks of the engine to get the timing marks around to the top where you can see them. might be two-three in andout of the car. But other then that VERY EASY!
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
Digital Self-tuning Forum Oct 10, 2025
gkomo
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
