Steeda Transmission Cooling Kit...Good or Bad Experiences?
MyEarsHurt
918
I am thinking about getting a transmission cooling kit from steeda, but I would like to know if anyone has had any bad or good experiences with them. Also I would like to know how hard the installation is, and where are you suppose to mount it? Thanks for the help.
I have it and I like it. I only had one problem with it and that was when a line on it broke and I ended up with a transmission fluid leak. However, thats cause the hose was bad.
Mine mounts on the front of the radiator. I didn't do the install but the guys who did it didn't have any problem getting it on there.
Lucky you just took pics for a fellow stanger. I installed mine using a thread on this forum. Cant remember from who :rolleyes:
Did the same thing as Dark Knight. Only problem i had was with the PS cooler in front. You can see the spacer i put in place to make enough space between the tranny cooler and the PS cooler. In the corner of the picture where the cooler goes tru the frame. 1/2" black spacer.
