  • SN95 V6 Mustang Tech
Steeda Tri-Ax Shifter
  • Thread starter Thread starter ChrisYellowV6
  • Start date Start date Apr 27, 2004
ChrisYellowV6
362
Pensacola, FL
Apr 27, 2004
  • Apr 27, 2004
I have an 02 vert, auto
Well I went home last weekend and brought back my grandmas SUV so I could bring home a bunch of stuff when I move out of my apartment this weekend, and she has the tiptronic auto in her suv. I have been driving it with that, and I really miss the control I have over the engine, so i've seriously been thinking about getting a tri-ax, but I have a few questions beforehand. On hers, it is the one you tip forward to go up and tip backwards to downshift, hence the name tiptronic (most people get sporttronic and tiptronic confused). This car doesn't let me go into a higher gear if it's not ready, if I put a tri-ax in my stand will this do the same thing? or is it whatever I put it in, thats it, period. Also, is this like a regular standard, with neutral in the center, gears 1 and 3 up top, and 2, 4, and R on the bottom? And when i'm downshifting do I put it in neutral and wait till i'm stopped and put it in first gear? because I have always been told on my standard, to hold the clutch in and keep it in gear, because if i coast in neutral, my seals get blown out easily. Anybody who knows about this, i'd really appreciate the help. Thanks. -Chris
A
atlblue2000
1,245
TN
Apr 27, 2004
  • Apr 27, 2004
I'm confused...are you wanting to put a Tri-Ax in your auto??? I kinda doubt that's possible.
seekjohn
23
Ontario Canada
Apr 27, 2004
  • Apr 27, 2004
a tri-ax shifter (as far as i know) i could be wrong though, is a shifter assembly for a standard transmission. It is called a tri-ax shifter because it is made mechanically to move the shifter knob closer to the driver of a manual transmission with a triple axis design. Maybe you are confusing it with a quick shifter that uses a handle and squeeze lever to shifter an automatic in a more sporty way
ChrisYellowV6
362
Pensacola, FL
Apr 28, 2004
  • Apr 28, 2004
eh probably am......my friend was telling me there was something i could replace the automatic drive selector with which makes it turn into pretty much a standard without a clutch....???? I thought that was the name of it but I guess i'm wrong
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
is my car dead
  • kenzo0315
  • Jun 30, 2025
SN95 V6 Mustang Tech Jul 8, 2025
kenzo0315
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
