Stereo Remote Wire
dmaxstang
dallas
I am trying to avoid having a 75 dollar labor fee to install my amplifier in my 05 gt. I have already built the box and installed it myself but i don't want to have to put in a shotty looking kill switch for the amplifier and would rather hook it up to the remote wire in the radio to kill the power to the amp when i turn the car off. Can anyone tell me where the remote wire is on the factory headunit. I have a Shaker 500. Thanks a ton stangers.
Ok, here is my buddy's answer...word for word...
"There is an 8-pin plug on the back of the radio and it
contains a light green wire with a purple stripe. That
is the amp remote lead. The only problem is that it
may output just 5 volts (instead of the 12 that is
required for an aftermarket amp turn-on). Ford has
been doing this for some time. If it does not work, he
will have to go to an alternate ACC 12 volt source or
add a toggle switch to activate the amp."
Good luck. Hope this helps you.
