I've posted this same question before, took heed to the advice, and still... no luck. My 97 bucks and misses and studders at any kind of a bind on the engine. (ie. heavy acceleration, or just puttin the peddal to the floor at 55 in 5th.) I dont know what to do... I've... changed the plugs (twice), added MSD wires, CHanged TPS sensor, changed MAF sensor, changed coil packs, and am runnin out of time and patience... then I pulled my codes and got a P1445. this has to do with the purge valve. So i replaced it. NO luck... and the code still comes up. What now? could a pinched line cause this? or is it sometihng else... I'm desperate now. If i can't soon find it out , I guess I'll be droppin it off at ford... and watch my pockets really empty out. ANY HELP IS APPRECIATED! I'm runnin out of ideas. Thanks guys
.....does it just keep spitting codes?? How long have you had it? I would take it to Ford and have them "diagnose" it for you so all you have to pay is that charge and you can do the work yourself if its something simple or figure out where you can take it for cheaper work.
