Stock 2003 Cobra Wheel Offset?
xendrik
I've been searching around on the internet looking for the specs on the stock wheels for a 2003 Cobra. So far what I have found says that they are 17x9 with a +26mm offset. Is this accurate? Are they the same front and back? If anyone has the answer or can point me in the right direction, I would appreciate it. TIA.
Short answer: I believe that is about right. I had +25mm offset.
Long answer: Its kind of weird. The rim width from outside edge to outside edge is more than 9". The true 9" width is at the tire bead. So the rims are actually a little wider than 9". Anyway the the offset is still +25 from the center on the rim.
Rogue Cobra
