ABSOLUTLEY WRONG!!! The purpose of the MAF is to determine the Mass of the air flowing in. Unless you screw up the reading of the MAF sensor by turning it, introducing turbulence by adding a bend in front of it, or contaminating it with oil from the filter the A/F is perfectly capable of adjusting for the increased air flow. The open loop base settings you refer to is the stabalized_open_loop_fuel table. This table depends on two things to decide what the a/f should be. RPM and the reading from the MAF. Well actually three things if adaptive was not turned off while tuning, which it should be. The third thing is the fuel adjustments that the eec learned during the last closed loop cycle. If adaptive was not turned off during tuning these adjustments WILL be applied back to the a/f ratio during WOT. Also this learning is done via the front o2's. The rear o2s have nothing to do with it or any other idle functions.
This is also partly incorrect. WOT is in open loop as well as startup. Basically you are in open loop anytime you are not in closed loop. The EEC shouldn't need to relearn anything if the MAF reading has not been thrown off. The releraning everyone refers to is actually designed to adjust for small corrections to the MAF reading. My first guess by looking at the orginal posters dyno charts would be to look for a vacuum hose that may have worked loose during the second set of runs.
