Stock Axels?
FordGuy88
241
Park Ridge, IL
I was wondering what kind of power will stock axles hold? Also how about the stock drive shaft? Would you guys sugest getting a FMS aluminum drive shaft? My buddy and me are building a Mustang with a 331 heads and cam car with a C4 and a 2800 stall converter. Stock rear end. will stock axles and drive shaft hold up? Car will be on slicks and skinnies.
Thanks
generally speaking stock axles and real power dont get along to well with slicks but its kinda hit and miss. Some people can run 10's with them and some break turning 13's so... As far as the DS goes for about 250 i would replace it anyway it helps with rotational mass and all that.
With that engine, your gonna want to upgrade your axles if your running on slicks. The two guys I have seen at the track break stock axles were both pulling 12.4s in the 1/4, I was doing around 12.5-12.6 and never broke mine, maybe I was lucky, I dunno, but snapping them was inevitable on slicks. I just finished installing 31spline Mosers. As for the driveshaft, it isn't necessary to replace it if your concern is durability, like said earlier though, it does reduce rotational mass a bit. For me, the cost of an aluminum driveshaft isn't worth it yet, bang for the buck, my money goes somewhere else for now.
Dont Cheap out! lol
I broke my stock drivers side axle w/ a mostly stock car. Just full exhaust, pulleys and a 76mm MAF...
I was running MT Drag Radials (not slicks)
I am upgrading to 31 Spline Moser Axles and an Auburn Pro Locker.
If you do decide to run the car w/ stock axles and slicks I HIGHLY suggest leaving the line at 2500rpm or even at idle...
You never know how the car was driven before you owned it...
As for the FMS Driveshaft, Get it! It will help with drivetrain vibrations and it wont snap as easily. I love mine.
Hope this helps.
Ken
