Stock Engine??
  • Thread starter Thread starter wfriedman
  • Start date Start date Feb 25, 2006
wfriedman
39
Sheridan, Arkansas
Feb 25, 2006
  • Feb 25, 2006
I think I have a stock engine on my 86 GT. The original Upper & lower intake manifold's are on, as well as 58MM TB. E6 Part numbers. The TB, EGR, both intakes, Valve covers, and heads have a blue colored sealer. Is this stuff original?? Or has this stuff been off?? The water pump looks to have been replaced. The sealer on it is an orange/red color?
Anybody remember what a stock engine gaskets and sealer looked like when doing s H/C/I or TB swap??
Thanks!!!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 25, 2006
  • Feb 25, 2006
looks stock except the k&n there. Remember that you don't have notched pistons so the heads you pick are limited. unless you have the pistons notched
wfriedman
39
Sheridan, Arkansas
Feb 25, 2006
  • Feb 25, 2006
I'm gonna pull the motor before it hits 200,000 miles. It has 165,000 on it now. Sounds high, but it's a 20 year old car so that's a little over 8,000 miles a year. I'll replace it with 87+ stuff.
I may need to do a compression test on it. It "feels" fine, but I have a feeling the valve covers haven't been off this car. I've had it almost two years and put less than 5,000 miles a year on it.
I put the K&N on. It had the original air-box when I bought it from a wholesaler.
I have no clue as to if it's been rebuilt or not. But it seems it hasn't
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Feb 25, 2006
  • Feb 25, 2006
yeas it seems to be stock. i looks at the pics and it still has the engine hoist hook on the drivers side
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
