Stock H-Pipe HELP PLEASE...
90'Stang5.0
Hey guys. I just picked up a 1990 5.0 LX which is in good shape. The only thing I needed to pass inspection was a catted H-pipe since it came with a BBK off-road.
I got it swapped out at a shop and drove the car home. After I let it idle for a minute, smoke started coming up from under the car at a pretty good rate. IT looked like it was coming from the new pipe. I parked the car, and shut it off. What could this be? The car ran good with the off-road pipe, so I dont think its anything motor wise. Is this a bad exhaust leak, something burning off, bad cats, or what??? :shrug:
If you installed a used h-pipe, the smoke is more than likely from oil or grease that got on the pipe during the installation process.
If you installed a new pipe, it's probably just some kind of coating burning off, along with some oil or grease from installation.
Take a look and make sure nothing is resting on the pipe, and burning up causing the smoke. If nothing's touching it, don't worry about it, the smoke should go away really soon.
Also if you have new cats, they can smoke and have a weird funk for a little bit.
If the issue persists or you have concerns, I'd contact the shop that did the install.
Good luck.
Yeah, sitting around the pipe will collect dust and grease and oil, which will cause that crap. It will burn off after a couple days, you should be fine.
Oh yeah....Make sure there ain't a banana in your tail pipe!!! :rlaugh:
Yea it was a used pipe. I think I'm going to take her out for a little tomorrow and see if everything clears up. If not I'll probably take it up to the shop later this week.
