stock slow
  • Thread starter Thread starter shttygtstang
  • Start date Start date Nov 30, 2004
1 of 2 Next Last
shttygtstang
978
  • Nov 30, 2004
ok ive been building my combo i did not do the 331 but went with a 302 roller block.well i got all my stuff runing and i took it out (forgot to put the fmu on but after i retimed it i put it on)dog slow wheels wouldnt even break if i power braked it i was like wtf so i checked my timing it was at 15* base timing .i didnt hear any detination but i still thought 15* was to high with 14psi so i put it at 10* this made it alittle faster wheels now break but its like stock
question is do you think my stock fuel injectors are maxed out i have a fmu from paxton . i didnt get to install my 38lbh injectors because i have a 30lbh sample tube from c&l ...idles fine starts right up dosnt over heat and my rrs are timed right im stumped
R
ratrapp
510
buena vista,va
Nov 30, 2004
  • Nov 30, 2004
what meter and injectors are you running?if you didn't use 38lb injectors then what did you use?
shttygtstang
978
  • Nov 30, 2004
stock 19.9lbh injectors stock maf aslo you think my base timing is still to high
shttygtstang
978
  • Nov 30, 2004
ttt
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 30, 2004
  • Nov 30, 2004
Were going to need more details to what you did to the car...a list of everything...
shttygtstang
978
  • Nov 30, 2004
VICTOR 5.0 INTAKE,F3O3 CAM , EDELBROCK RPM HEADS 1.90 INTAKE 1.60 EX, ADJUSTABLE FUEL REGULATOR ,PAXTON SN SERIES WITH THE VR4 UPGRADE 14psi, C.A.T ROLLER TIP ROCKERS WITH 7/16 STUDS base timings at 10* and the stock injectors and maf are on with a fmu
thats whats on there now but i have a box full of stuff to go on
sprayed88stang
31
ltown
Nov 30, 2004
  • Nov 30, 2004
help
bigger injectors will help is ur throttle body side ways c&l have to be mounted with ur connection up and down make sure the fmu is still working
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 30, 2004
  • Nov 30, 2004
I would recommend getting these problems fixed before adding the other stuff to help pinpoint a potential problem...
The timing will need to be more than 10*, what is your fuel pressure at with the vacuum line off?, spark plug gap?, those stock injectors are just asking for trouble with h/c/i and a supercharger?...
shttygtstang
978
  • Nov 30, 2004
it ran like crap at 15* base timing
fuel pressure im not shure i have no gauge spark plug gap is the stock gap out the box i was told to leave em there pre gapped
as for the box full of stuff thats why i didnt put it on yet one thing at a time
i thopught the timing was suppose to be lower for forced induction
Funanin
356
Horsham, Pennsylvania
Nov 30, 2004
#10
  • Nov 30, 2004
  • #10
I agree, 19# injectors must be really giving it all they got. BUT, anyone can do a burnout with a stock 5.0, so i would say its something with ur FMU or fuel pressure. Check ur FP because it should be at least 40 with a blower on there. And if its at like 50 then maybe its too high for the injectors. I dunno im talkin out my ass.
shttygtstang
978
#11
  • Nov 30, 2004
  • #11
i have no clue what you mean my c&L isnt on there because its calibrated for 30lbh injectors and i have 38s my tb is up and down the way it was suppose to be
Funanin
356
Nov 30, 2004
#12
  • Nov 30, 2004
  • #12
order one that hooks onto ur schrader valve on ur left fuel rail. They are like 40 bucks and make a hell of a difference when trying to tune a highly modded car.
shttygtstang
978
#13
  • Nov 30, 2004
  • #13
i know im trying to get on thing at a time though i dont wanna spen any money if i dont have to the car ran great before i did theese mods
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 30, 2004
#14
  • Nov 30, 2004
  • #14
Yeah the timing is usually "down" compared to N/A cars...but I still believe it should be higher...but I don't know...
Anyways...the spark plug gap/MAF calibration/FP need to be figured out...or fixed...
With the power that car should make...the 19lbers simply aren't going to cut it...I wouldn't drive it hard until you get those problems fixed for risk of other problems...
Good Luck
shttygtstang
978
#15
  • Nov 30, 2004
  • #15
fmu gets vacume or boost its hooked to my intake manifold now
its sitting i dont drive it its my lawn ordiment
shttygtstang
978
#16
  • Dec 1, 2004
  • #16
ttt
9
9150ho
83
#17
  • Dec 1, 2004
  • #17
do you have a boost gauge? are you seeing boost? timeing should be at 10*, or you can run with spout out at a constant 20-25 degrees, I believe.
shttygtstang
978
#18
  • Dec 1, 2004
  • #18
ya i seeing boost boost gauge isnt hooked up but after a wot my bov screems a sigh of relief and my bov is set at 10psi so theres more than 10psi there
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 1, 2004
#19
  • Dec 1, 2004
  • #19
With your adjustable fuel regulator your going to need a pressure guage...you need to know where that pressure is at...your going to have to bump HIGH to make those 19lbers even work somewhat safely...you need to get a MAF and injectors calibrated together to solve a few of your problems?
www.50resto.com sells them for $40 bucks and it is the one that goes on your schrader valve...I have one and it works just fine...
Find what your plug gap is at...make sure your running higher octane (93 atleast)...
Again Good Luck
shttygtstang
978
#20
  • Dec 1, 2004
  • #20
were do i get the c&l sample tubes from
my fuel pressure regulator is all the way open also that made it run a little better
1 of 2 Next Last
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • dan50
  • Jul 18, 2026
dan50
is my car dead
  • kenzo0315
  • Jun 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 8, 2025
kenzo0315
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
9K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
