Stock Springs
  • Thread starter Thread starter 04dsg mach
  • Start date Start date Aug 21, 2005
04dsg mach
20
Northern Virginia
Aug 21, 2005
  • Aug 21, 2005
hey i was trying to finish up the front brakes on my 50 and im still using the stock springs so i was wondering how did you guys get the stock springs back into your car.? my brother and i have tried 2 types of spring compressors and neither have worked!! so could you give me ideas
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 21, 2005
  • Aug 21, 2005
Stock springs are tough.
WHat i did was dangerous, so only try it at your own risk.
I used a spring compresor to compress the spring just far enough to slip it in place. Then i used long hose clamps to hold the spring compressed. I used about 20. Some guys use wire. It held, and i was able to put it back in.
But like i said, it's dangerous so try it at your own risk.
The proper way to install stock springs is to disconnect the A-arm at the k-member and connect the strut to the spindle. Place the spring in the perch and jack the arm up into position and try to line the bolts back up.
GearHd6
459
Ashford, CT
Aug 21, 2005
  • Aug 21, 2005
Emphasis on the "try to line the bolts back up" because that method is a pain but that's the safe way to do it. Its safe practice to attach a rugged strap to the spring and attach it somewhere to the car just in case something goes wrong. A loaded spring can cause serious injury or death.
28
22
  • Aug 21, 2005
Shell out $200 for a set of lowering springs and save from doing it twice...Plus it's easier to install the lowering springs than the junk stockers..Good luck..
juiced_94gt
1,143
Southern California
Aug 21, 2005
  • Aug 21, 2005
a very big pry bar is what i used to use at the dealership.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Aug 21, 2005
  • Aug 21, 2005
i found a coil spring compressor at Pep Boys that i compressed em with and then put them back in....I was able to then jack the A-arm back up and take the compressor off inside the spring and shimmy out all the peices through the hole in the A-arm.
I have heard it is easier to unbolt the back of the arm ad just jack it all into place...but i dunno.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 21, 2005
  • Aug 21, 2005
I used the correct spring compressor and it made life much easier! Its expensive, but has 2 flat plates that go in between the coils and the threaded rod comes up through the bottom of the A Arm. It weighs around 13 Lbs too so it is a solid safe tool.
old_blue
1,783
282
124
Aug 21, 2005
  • Aug 21, 2005
I used a spring compressor (the wrong type) to get it to where I could put it back in enough to then use the floor jack under the "A" arm. When I put in my lowering springs it was easier and I love the difference. My 400th post YAY!
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
