Strange Knocking Noise Coming From Front End. Help!!!
zhendo95
Tempe, Az
What's up guys,
Here's a link to my last post, It will tell you everything you need to know about the mods I have on my 97.
http://www.stangnet.com/mustang-forums/threads/just-purchased-1997-mustang-gt-need-advice.889715/
Yesterday I was driving down the free way crusing about 75 MPH. Out of no where I noticed this strange noise which seems to be coming from the front drivers side wheel area. The noise is only noticeable above 65 mph. The best way I can describe the noise: It sounds as if the hood is latched but not fully secure and its bouncing up and down. Just a constant knock and it sounds as if it's happening and every full rotation of the tire. I got off the freeway and noticed the same sound when I came to a hard brake. I got to the place I was headed and looked under the car to see if I could find a brake pad hanging off. I noticed a piece of plastic from the wheel well that was torn so I kind of shimmied it to get it into a better position. I left my location and hopped back onto the free way and about 10 miles into the drive the slide started again.
All I know for sure:
Occurs after 65+
Noticed a bit more shaking of the steering wheel.
Seems to happen again at a hard brake.
Unsure of:
If it's just during acceleration or at both acceleration and coasting.
Where exactly it's coming from
I'm going to get under the car today to see if I can recreate the noise. If you guys have any ideas about what it could be or a specific place to start looking that would be great!
Thank you!!!
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
Jarrod Engine Strange Knock/shake. SN95 4.6L Mustang Tech 8
Strype Strange Knocking SN95 4.6L Mustang Tech 0
screamin gt Strange brake noise, hot front brakes 1996 - 2004 SN95 Mustang -General/Talk- 5
P Drivetrain 1995 GT Auto Transmission Acting Strange 1994 - 1995 Specific Tech 1
S Strange sound coming from under car? 2001 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 1
B 2011 - Strange lock / unlock behavior with key fob. 2010 - 2014 Specific Tech 4
B Strange Tail Light Problem 2005 - 2014 S-197 Mustang -General/Talk- 0
S Suspension Strange sound while driving. Sounds like cards in bike spokes. Fox 5.0 Mustang Tech 5
9 Need held, Strange Sound at Ignition Fox 5.0 Mustang Tech 2
N Strange over heating issue. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
5 Strange misfire or sputtering Fox 5.0 Mustang Tech 5
D Engine 94 5.0 strange oil leak 1994 - 1995 Specific Tech 7
CHILL347 Suspension Strange 10 way adjustable rear shocks? Fox 5.0 Mustang Tech 9
N Strange question..... SN95 4.6L Mustang Tech 2
Cort Strange misfire after downshifting 1994 - 1995 Specific Tech 7
F Engine Strange drivability issues and can only pull koeo codes Fox 5.0 Mustang Tech 27
9 Microsquirt with strange cold start problem Digital Self-tuning Forum 5
R Right rear clunk when hitting bumps 2015+ Specific Tech 6
EZ123 89 LX stall out and strange idle Fox 5.0 Mustang Tech 9
Spooky21 87 LX - strange fuel pump eccentric 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
GDawg 1998 GT - fuel gauge strange light SN95 4.6L Mustang Tech 0
Z Strange Noise 1996 - 2004 SN95 Mustang -General/Talk- 2
S Strange Noise Under the Hood Help Needed! 07 Mustang GT 2005 - 2014 S-197 Mustang -General/Talk- 3
V Suspension eibach drag launch and strange shocks Fox 5.0 Mustang Tech 0
W Strange fuel pump issues 1965 - 1973 Classic Mustangs -General/Talk- 1
F 2001 Mustang Cobra - Strange Electrical Problem SN95 4.6L Mustang Tech 5
Calebnc302 03 Gt Strange Problem 1996 - 2004 SN95 Mustang -General/Talk- 0
Jimmy K jam Strange Engine? SN95 4.6L Mustang Tech 1
F Brakes Strange Brake/suspension Noise 1994 - 1995 Specific Tech 4
imp Strange New (to Me) Device 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
R Strange Hollow Sound 1996 - 2004 SN95 Mustang -General/Talk- 7
General karthief Strange No Start Condition Fox 5.0 Mustang Tech 16
cmerk27 Engine Very Strange Coolant Leak (checked All The Basics) And Other Problems SN95 4.6L Mustang Tech 20
D Strange Struts 4cyl Or V8 Spindles Fox 5.0 Mustang Tech 11
D Strange Issue 1994 - 1995 Specific Tech 4
N Strange Throttle Body Plenum On 99 Gt SN95 4.6L Mustang Tech 1
W Electrical Headlight Nob Is Acting Strang SN95 4.6L Mustang Tech 2
P Strange Tach Problem 1994 - 1995 Specific Tech 2
D Strange Vibrating Noise 1996 - 2004 SN95 Mustang -General/Talk- 3
I Strange Gurgling Sound In Exhaust SN95 4.6L Mustang Tech 51
T Engine Strange Issue 94 Gt 5spd, Losing Power, No Codes 1994 - 1995 Specific Tech 1
blistovmhz Strange Electrical Gremlins - Ignition 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
fox-gt Strange Noise Since 3g Alternator Upgrade Fox 5.0 Mustang Tech 8
lepryy Need Some Help With Turn Signals. Plus A Very Strange Module Found Under My Steering Column. (videos Fox 5.0 Mustang Tech 11
D Electrical Strange Wire In Harness Fox 5.0 Mustang Tech 11
Z Expired Complete Team Z Strip Series 1 Rear End, Strange 10 Way Adjustable Rear Shocks, Upr Torque Boxplates Suspension Parts 6
02shtangGT Engine Strange Humming/growling Noise Behind Dash?? 02 Mustang Gt SN95 4.6L Mustang Tech 2
V 2006 Mustang Convertible V6 With Strange Fluid Leak 2005 - 2014 S-197 Mustang -General/Talk- 2
guitars_cadillacs Strange Problem SN95 4.6L Mustang Tech 2
B Strange Noise From Air Intake 1996 - 2004 SN95 Mustang -General/Talk- 4
