  • SN95 4.6L Mustang Tech
strange problem after re-installing egr
  • Thread starter Thread starter sbelyo
  • Start date Start date Jul 18, 2005
sbelyo
192
  • Jul 18, 2005
I had a strange problem after I tried to re-install my egr valve. I removed it and started the car for 10 min. and it started and ran fine. I decided to put it back on after two days of sitting. Once everything was re-installed I started the car. It would crank over but would not stay running unless you pressed on the gas pedal immediately after cranking it and then continuing to hold it. CEL would come on as soon as the engine would die.
1. I took it back off and installed the blocking plate and plugged the green vacumn line, and reset the PCM. No go
2. I unplugged the sensors leading from the EGR. No go
3. I turned off the EGR switch with a predator and cleared the codes. No go
4. I pulled the PCV vacumn line and cranked it once. No go
5. I plugged the PCV back in and started it about 5 min. later and whamo it ran like a champ. But the CEL was on.
6. I cleared the code (it was P1000) and let it idle for 30 min. No CEL and running fine
7. I drove it for 10 min. and all is well.
Now why in the sam hill would that happen? It's supposed to crap out when you take stuff off, not put it back on.
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 18, 2005
  • Jul 18, 2005
You install the gasket? Could be a clogged EGR tube, check the wiring and see if it's pressed in all the way.
sbelyo
192
  • Jul 18, 2005
I did install a gasket, and double checked all connections..
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
