Hi guys,
Recently installed the Trick Flow Track Heat top end kit on my '93 LTD (Australian, but same 302 as in 94/95 'Stangs) but I now have a mystery vacuum leak somewhere, on engine shutdown it will hiss for about 10-20 seconds after it's stopped running, and will then let out an almighty "squeal".
A short rundown of mods which may be related/help are:
Rebuilt 302
TFS top end kit
Crane Hi-6, LX92 coil
Pertronix TFI module
Ford Racing 24lb injectors (M-9593-AA302)
Aeromotive fuel system
70mm T/B
70mm MAF
MSD leads
Falcon GT ECU (factory tuned for MAF and 24lb injectors)
3.27 diff gears (yes, I want 3.7's)
T5Z manual
Here is a short Youtube clip to show the sound, you will hear it at the end when I turn the engine off:
It also bucks horribly on part throttle, even above 2000rpm, which is leading me to believe it's a vacuum leak somewhere. All the vac fittings under the intake are sealed with that non-hardening Loc-tite liquid sealer (shellac?). So I'm thinking maybe I should use Teflon tape.
Cheers!
Rebuilt 302
TFS top end kit
70mm T/B
70mm MAF
MSD leads
T5Z manual
Cheers!
