strange starting problem
  • Thread starter Thread starter trlprk
  • Start date Start date Dec 7, 2010
T
trlprk
58
Rhode Island
Dec 7, 2010
  • Dec 7, 2010
Hey guys, I am having a strange problem when I try to start my 91 lx. When I try to start it, there is a delay from when I turn the key to when the starter will engage. It dosen't do it all the time, usually when its cold (mornings always), sometimes it will delay so long, I have to keep bumping the key, eventually it will turn over. Also two days ago, when I tried to start it, I couldn't hear the fuel pump run. I popped the trunk and tapped the inertia switch and tried it again and it started. Any ideas?
Cobra1741
152
  • Dec 7, 2010
do you hear the pump turn on with the key just on??? if so then you bump it to start it, it might just be that bendix sticking or something...
Kdubslugga
1,515
Akron, OH
Dec 7, 2010
  • Dec 7, 2010
delay..like it cranks for a long time before it fires,or you actually turn the key and there is a delay in the cranking?
T
trlprk
58
Rhode Island
Dec 8, 2010
  • Dec 8, 2010
delays like turn the key to start it........starts cranking over after two to sometimes five seconds. When I put the key into the on/run position, you can hear the pump kick on, when the car decides to start turning over, it starts every time. Two days ago, the pump didn't kick on, I popped the trunk and tapped the inertia switch and tried again and it started right up. I think it might be two seperate problems. Ignition switch and inertia switch?
LarsD
2,680
119
123
Texas
Dec 9, 2010
  • Dec 9, 2010
Could be your starter relay going out. I had this happen on my old 89 years ago. Started doing what you are describing, so I replaced it and it never did it again.
HISSIN50
34
129
Dec 9, 2010
  • Dec 9, 2010
Put a test light on the solenoid trigger and see if it illuminates as soon as the key is turned to crank.
Is there any chance you sub-consciously push the clutch pedal down further as this occurs (meaning the pedal needs to be through the floor to close the interlock circuit)?
T
trlprk
58
Rhode Island
Dec 10, 2010
  • Dec 10, 2010
yeah, I have moved the clutch pedal around a bit when I am trying to start it, didn't work though. putting the clutch down like normal and just waiting, it would eventually crank over. I have been too busy to check anything out this week, but I will work on it a bit this weekend.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
