Ok, I have a new water pump on the newly rebuilt engine. The last two days it has had a few drops under the balancer on the floor. It is coming from the weep hole.
However, It dies not do it while running and only when I let it sit overnight. Very small amounts.
Another thing that was weird is that when i went to check the coolant level, it still had pressure on it. So, I drained a bit from the radiator, cleaned everything up and ran it until operating temp and so far it has not leaked out of the weep hole.
Should i just go ahead and replace the pump?
