Stripping undercoating from underside?
  • Thread starter Thread starter 1973mach1
  • Start date Start date Mar 9, 2004
1973mach1
457
PA
Mar 9, 2004
  • Mar 9, 2004
Any ever strip the undercarriage of their car? I was under mine today and the undercoating is flaking off in several spots down to the metal and rust is showing, i'll be pulling the engine, tranny, and driveshaft anyway so I thought this might be the best time to strip it down to the metal, sand down the rust and por-15 it and the engine bay. What would be the easiest and fastest way. The undercoating is still real thick in some spots.
Thanks,
Jim
1320stang
4,329
23
89
Edmond, Oklahoma
Mar 9, 2004
  • Mar 9, 2004
Easiest and fastest would be to hire someone else to do it. Short of that, a heat gun and some scrapers is about the only way I know of with the car still mostly assembled.
allcarfan
The Answer Man
2,458
North Atlanta
Mar 9, 2004
  • Mar 9, 2004
This job is a BIG BIG BIG pain in the butt. the BEST way to do it is to have your car acid dipped...however, you have to strip the car down to nothing to do so.
Getting under the car when its not on a lift to do this makes it a real chore. Like 1320 said...a heat gun and a few scrapers will do it....following by a diegrinder with a sanding wheel and a wire brush attachment also. i began to strip my undercoating off, but there was no point in it. It was still intact.
66 BLAKE 96
Native Texican
4,810
Cowtown
Mar 9, 2004
  • Mar 9, 2004
There was a guy 'round here that swore by this stuff: http://www.propaintstrip.com/search...chParamMan=ALL&txtsearchParamVen=ALL&iLevel=1
I can't remember his screen name, but he did write ups on his trunk and rear wheel area, and it looked amazing. Personally, I went with the scraper/wire wheel method when I did mine. It sucked, but the warm happy feeling of knowing that the whole underbody structure of my car is clean, handled, and rust-proofed is really nice.
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Mar 9, 2004
  • Mar 9, 2004
I used a wire wheel attached to a drill.
but I went over it first with a putty knife and a chisel. the stuff was dry enough to break off the big chunks, then I cleaned it up with the wire brush.
dolfan87
1,242
Lake Havasu, AZ
Mar 9, 2004
  • Mar 9, 2004
I had mine sandblasted. It was like 700.00, but the car was nice and clean, and I didn't have to do it.
After stripping 30 years of prior paintjobs off the top side, I was not going to lay down and do the underside that way.
1973mach1
457
PA
Mar 9, 2004
  • Mar 9, 2004
Thanks, I think i'll just spray the rust spots for now and take it to get sandblasted when I get the $$$.
Jim
G
GaPonyFarm
663
Columbus, GA
Mar 10, 2004
  • Mar 10, 2004
I sandblasted mine, with the car on jackstands. After two weeks on my back, eating crap, it was done... $700 is a steal! I'd never go through it again...
M
matt d
167
Coventry, CT
Mar 10, 2004
  • Mar 10, 2004
Eastwood sells some undercoating remover that actually works if you get most of the thick stuff off first. I used a stiff putty knife and scraped most of the big pieces off then I soaked the underneath with that undercoating remover. It sort of dissolves the stuff so that you can easily get it off. I think I used a scotch-brite type pad to scrub off the dissolving undercoating. It is so nice to have all that crap off the bottom of the car.
XeonTux
30
#10
  • Mar 10, 2004
  • #10
I think this is who you you might be thinking of, I don't remember who he is on here either, but I made note of the following urls
http://www.svend.net/mustang/ww73/ww73.html
http://www.svend.net/mustang/peelaway7test.html
I plan to strip and POR15 my underside and wheelwells this summer. I might give Peelaway 7 a try.
Platonic Solid
1,960
CT-USA
Mar 30, 2004
#11
  • Mar 30, 2004
  • #11
Thread Resurrection
Here's my original thread on the Wheel Wells:
[thread=338280]How I Cleaned & Por-15'd My Rear Wheel Wells (pics & link)[/thread]
Svend
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
My 67 project
  • hungrymonkey
  • May 5, 2018
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 26, 2018
J-Scratch
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
71K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
