  • SN95 4.6L Mustang Tech
Stroke It or Bore It??????
  • Thread starter Thread starter SFStangGT
  • Start date Start date Sep 4, 2004
  • 3
First Prev 2 of 3 Next Last
W
WOT
2,817
Regina, Canada
Sep 4, 2004
#21
  • Sep 4, 2004
  • #21
Stroking a 4.6 is a waste of money. Most of the guys that have done it wish they didn't.
Besides you can make awesome power without it. Concentrate on the heads and the cams.
UVBNHAD
144
McCalla, AL
Sep 4, 2004
#22
  • Sep 4, 2004
  • #22
I'm wondering what those main parts are myself? Would it be crank, rods, pistons, bearings because those are all replaced when you put in a stroke kit. What other main parts are there?
I kinda agree with the above post though. Stroking/boring a 4.6 is almost pointless because of the power you can produce with a blower or other modifications.
M
MineralGray02
11
#23
  • Sep 4, 2004
  • #23
wuts best for a twin turbo set up? cause thats in the works right now and i need some help determining how to run over 10 psi without frying my engine
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 4, 2004
#24
  • Sep 4, 2004
  • #24
well i guess following that mechanics theory, you shouldnt put in forged internals because that would be changing the main engine parts. the mechanic my family went to has been turning wrenches for 30+ years, he retired, but he still works on our cars at his house. he is old school, but he still keeps up with all the current trends for working on cars. the mechanic that told you that shouldnt be allowed to touch anything newer than 1980. im sure he also recommends arco graphite oil, putting in STP at every oil change, and still says that we should be running carbs and leaded gas.
for the twin turbo setup, i would suggest running a 03/o4 cobra crank, some manley rods and CP pistons. if you want you can go with a big bore setup, as that will allow the air inlet charge to go in easier because of the unshrouded valves. however the big bore makes the cylinder walls thinner and theoretically could make them weaker. so just use a stock bore and stroke, maybe a .020 or .030 overbore if there is a ring ridge.
M
MineralGray02
11
#25
  • Sep 4, 2004
  • #25
good info, thx, is there anything else anyone reccomends?
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Sep 5, 2004
#26
  • Sep 5, 2004
  • #26
4.6's need more bore. they have plenty of stroke already.
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
Sep 5, 2004
#27
  • Sep 5, 2004
  • #27
as a first year auto technician student, im no expert.......however, you must break it down to the basics i.e. what gives you more power? power comes from the air and fuel into your engine. the more air and fuel you can cram into the combustion chamber, the easier you can make power. thats why turbos and blowers are so popular: they compress more air into the chamber. IMHO, i would bore over stroke any day. if you only stroked the car with no other modification to the engine, you would just get a higher compression ratio (which isnt necessarily bad) and longer moving parts, which are not ideal for higher reving engines, although there are exceptions as we see from michael kidd's beast. whereas when you bore an engine, you allow more air and fuel into the chamber for a bigger "explosion". ideal, you would want to bore and stroke at the same time, but if i had to pick, i would say bore. but not too much b/c, as mentioned earlier, the more metal you take away from the block, the weaker it becomes. not good for a high horsepower car. there are always sacrifices tho.
kah9911
102
Downingtown, PA
Sep 5, 2004
#28
  • Sep 5, 2004
  • #28
Well the big bore has proven to be a bit more powerfull everything being equal. It unshrouds the vaulves like some stated above. But the down side is it can only be done on a aluminum block. The stroker can be done on your iron block. If you do either put forged internals in because you have it torn apart anyway.
Here is some "light" reading for you. There was a good discution on MD a while back about this so hope you have plenty of time.
SFStangGT
53
South Florida
Sep 5, 2004
#29
  • Sep 5, 2004
  • #29
Sounds to me like boring or stroking is a waste of time on our 4.6's. Better off just saving the money and put it into better pistons, crank, rods, heads and block. As with Micheal's car, he had a completely built engine (internals, heads, custom cams, etc..) and a great tuner. Was it really the stroker kit that made his beast??? That is why I started this thread, I was wanting to know which is better and if either was even worth it.
super street
38
houston
Sep 5, 2004
#30
  • Sep 5, 2004
  • #30
big bore is ok on n/a cars, but horrible on the forced induction side. i wouldn't reccomend doing it because too thin of walls causes block failure.
stroker is a toss up, you get more low end torque but if you're going forced induction you need a bigger blower to compensate for the extra inches. i've never heard or seen anyone using a modular n/a stroker.
as for the stroker having a slow rev, i haven't noticed anything going slow on mine.
super street
38
houston
Sep 5, 2004
#31
  • Sep 5, 2004
  • #31
white99gt said:
Really and where have you seen block failure on a big bore with boost?
I personally say a stroker of big bore is not worth the extra money..Use it to add other parts to the car..
there's a guy down here that had the big bore w/a kenne bell pushing 15# and cracked the block.
white99gt
4,649
stockbridge,Ga(near atlanta)
Sep 5, 2004
#32
  • Sep 5, 2004
  • #32
SFStangGT
53
South Florida
Sep 5, 2004
#33
  • Sep 5, 2004
  • #33
I think I will have to agree with a person who is putting down over 600rwhp on pump gas. You might actually know a thing or two.
white99gt
4,649
Sep 5, 2004
#34
  • Sep 5, 2004
  • #34
I know a few things..Ive turned every wrenchon my own car besides the building of the motor itself..But everything else was done by me..
Nothing against any of the other high hp cars with bigbore /stroker motors..I just think a stroker/big bore is not needed..If you have the extra cash fine..But a few thousand dollars goes a long way into a new tranny or rear setup to hold the power..Plus how much power do you really need in a street car ..
super street
38
houston
Sep 11, 2004
#35
  • Sep 11, 2004
  • #35
yeah a 600+ hp car that runs 11.60s.
white99gt
4,649
Sep 11, 2004
#36
  • Sep 11, 2004
  • #36
Guess you were not bright enough to look on my mods page and see i ran 11.60 with 481rwhp and a race wieght of 3610 on dot drag radials..
stallion98gt
1,802
Los Angeles, CA
Sep 11, 2004
#37
  • Sep 11, 2004
  • #37
G
GinoGT
1,862
Sep 11, 2004
#38
  • Sep 11, 2004
  • #38
HpMan said:
I hear stroking the engine is bad for your car cause youre not upgrading other main parts. My mechanic told me its detrimintal (sp) for the engien! MY mechanics been workin on fords for 20 years! I think he knows more than you people!
Yeah, he sounds like a real pillar of automotive knowledge.
See what happens when you don't know what you're talking about?
Mossberg
ATL, Shawty
Sep 12, 2004
#39
  • Sep 12, 2004
  • #39
Ask Michael Kidd (screwed2v I think) if a stroker is a good idea on a 4.6 2v.
G
GinoGT
1,862
Sep 12, 2004
#40
  • Sep 12, 2004
  • #40
It is if it's going on a turbo/supercharger setup. N/A you're shooting yourself in the foot.
  • 3
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
