I am about to build a 331 stroker to put in my 1995 GT. I have looked at threads on multiple forums but cannot find the answers I am looking for so any help would be great, thanks. (Carbureted, A/C Delete, No smog)
1) what water pump should I use? Do I need a High Volume water pump or will a stock replacement work?
Are the stock radiator and e-fan up to the task of a stroker?
2) Do I need a high pressure oil pump? Or can I use the stock pan and stock oil pump?
3) With an edelbrock airgap intake and carb, will the stock hood (1995) clear everything?
4) Do I need to sump a stock tank? or can I just use a pickup to get rid of the efi fuel system?
5) Are underdrive pullies usable in this application?
6) What is your stroker build list? and how does it perform?
This car will mostly be a street car and do not plan on revving the motor of 6k rpms.
I know but since I already have the carb.. I will have about 250 in an intake... I'm going to have to buy a new tank with fuel pump anyways... will still be cheaper to go with carburetor. It will all be ok lol
