stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Sep 12, 2007 #1 Sep 12, 2007 #1 I have damaged the threads on the front of my crankshaft. I can get a 331 crankshaft fairly cheap. Is it possible to run a stroker crank with stock rods and pistons?
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Sep 12, 2007 #3 Sep 12, 2007 #3 Unfortunately no it will not. You have a 3" crank throw stock with a 5.090" rod, and a 1.6" compression height piston. By adding a 3.25" crank (331 crank, with 1/4 in.), it just will not work without sticking the piston out of the top of the deck.
