I got a 331 Stroker motor in my car with TrickFlow twisted wedge Heads and Intake, E303 cam, 75mm TB, MSD 6AL, Autolite 3492 gapped at 0.052-0.054 (ford spec), ect ect .. I got some timing questions ..
1) Do we need to have the car OFF when pulling the SPOUT out before adding/removing timing.
2) My car has a lot of hesitation if I am around 10* thru 24*ish pretty un-drivable with SPOUT out but at 30-32* she run's very good!
3) If I set it at 32* because I have aluminum trick flow heads when I pop the SPOUT back in should it drop back down to 10* as with SPOUT out is that setting the total desired base timing?
4) Any of you guys just running motors/setups like this with the SPOUT out successfully. (Locked out Timing I think you call it)
My car really need's a tune which I am working on now going with an Anderson PMS or QuarterHorse which I am sure I could do all of this right then and there in the tune.
Just really curious as I thought I was supposed to with SPOUT out set the base timing to 10* but seriously runs like crap yet setting it at 32* runs like a champ.
Any input would be greatly appreciated guys thanks ..
