Strut Rod Installation
  • Thread starter Thread starter 6Stang7
  • Start date Start date Feb 12, 2010
6Stang7
1,470
Livermore, CA
Feb 12, 2010
  • Feb 12, 2010
I'm replacing the strut rod bushing and I'm wondering if there are any specifics with respect to the two large nuts that compress the bushing. There was nothing about it int he shop manual I have, and I'm not sure if I just wrench one nut down tight or try and do it to both.
EDIT: BTW, I did go with rubber over poly to avoid strut failure.
noroof66
10
  • Feb 13, 2010
I show 40-55 lbs for strut to underbody.
JonK
276
Nashville (Smyrna), TN
Feb 13, 2010
  • Feb 13, 2010
They're going to need to be adjusted again when you get your alignment, the strut rods change the caster so when you removed the old you lost your correct caster setting. When I did mine I just snugged up the rear nut so that the bushing was just being compressed, then did the same to the front one. You won't get them right w/o an alignment. I'd drive straight to the alignment shop or you could ruin your tires w/in 100mi. of driving with bad settings.
For a good explaination of alignments get this months (Feb. 2010) Modified Mustangs & Fords, it's all classic now and there's a good article explaining it in there.
Jon
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
H
Hello all from my shop, Tod/ Tods Hot Rods, located in Moorpark CA 93021. Longtime 25 Yr Restoration/Performance Shop and Custom Builder Owner. Tod
  • Hot Rod Tod
  • May 28, 2024
  • The Welcome Wagon
The Welcome Wagon May 28, 2024
LILCBRA
