Strut Tower Brace vs Breather Valve
criticman
723
Rome, GA
Okay...any brilliant ideas to fix my mistake...
I have a '93 LX 5.0 and installed a BBK strut tower brace about a year ago.
Well, along with a lot of other random upgrades (mostly suspension), I ordered a Ford Racing crankcase breather cap (you know, essentially a pretty oil fill cap with a filter - which will be useful more so in the future when I step up to twin turbos).
The problem is, the breather cap is about 1" too tall to fit up under the strut tower brace. :bang: So, anyone with some awesome idea to sovle this dilema? I should've known it would be an issue since changing my oil is awkward trying to get the funnel nicely into the oil fill tube since the strut tower brace is right over it.
So if you have an idea that would let me keep this breather cap AND make filling oil easier, awesome, please let me know (ideas such as a replacement fill tube that comes out at an angle would be cool if you know of a place that sells them (and if the install is simple), or some ghetto mod using items from Lowes/Home Depot to make things easier).
Thanks! If no one has any ideas, I will be taking advantage of JEG's nice return policy.
I had the same problem. I took a pipe cutter and cut the filler neck a few inches. I then went to autozone and got the 'push in' breather that has the rubber gormet instead of the screw in one. Never had a problem with it.
The one I have is a push in type..so that could work.
How hard is it to remove the filler tube? I am assuming you removed it to cut it so as not to get metal shavings in the oil system :-)
And what is a "puke can" ?
I didn't remove the neck. I stuffed a clean towel down in there and used the pipe cutter. You should get much shavings from the cutter. My car wouldn't idle right when I connected the hose (from the neck) to the intake, only with it off. So I plugged the hole and use the breather.
