I had to open up the steering column end on both of my cars like Mustang5L5. I think I used a small pry bar and it was just the opening due to the bolt collapsing it when the cars were assembled or at least that was my thought.
Hopefully you have some or can get some tie wire like this:
Like Mustang5L5 was getting at take a couple of strands and run the ends through the bolt hole and back out the opening in the steering column shaft and use a pry bar to pull the inner shaft back out.
This thread shows one way of doing it.
stangnet.com
Fox - Stuck Power Steering Rack
Good Afternoon folks; I hope you had a great new years. I need your expertise with a stuck power steering rack on my 93 foxbody (picture attached). The passenger side is pulling out fine. The driver side is stuck to the bushing and I am not able to pull the rack out of the K-member. My...
