Stud/Pedistal mount rocker arms?
  • Thread starter Thread starter FeTTstang
  • Start date Start date Nov 30, 2006
F
FeTTstang
61
  • Nov 30, 2006
Hey is kinda a dumb question that I should know, but what are the differences between stud mount and pedistal mound rocker arms? Also is 3/8 stud the stock SBF size? Will 7/16 stud mount rockers take any machining on the heads. If I get 1.7's will I need bigger valve covers? Someone fill me in on this please.
L
Lxstang306
33
  • Nov 30, 2006
u can add the 7/16s stud to your heads. machine shop can do it not sure what it will cost . with a 7/16 is stonger then pedistal mound. pedistal mound rocker torque to 20 pounds that all no ajustment. with the studs u can ajust them. pedistal mound rockers only have a 5/16s bolt to hold them down so stud is stonger. with stud u have to have gide plate. stock ho valve might not clear.
O
OrLackThereof
560
Palm Bay, FL
Nov 30, 2006
  • Nov 30, 2006
Stock HO valvecovers will clear 1.6 full RR's IF and only IF you grind the baffles out of the insides. Now as far as 1.7's, I don't know you'd have to grind the covers and then test-fit them I suppose, and make sure the rocker arms have enough clearance to fully open and close
DucatiRdr
271
North of Boston, Massachusetts
Nov 30, 2006
  • Nov 30, 2006
I have the Ford Racing 1.72 blue rockers on my e7 heads and the only bit I changed on my valve covers was removing the baffle below the oil fill tube. No clearance issues whatsoever.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 1, 2006
  • Dec 1, 2006
I fit '93 Cobra/Crane Energizer rockers(1.7) under some stock cast covers('89) by making a thinner sheetmetal baffle for the oil filler. Now they barely fit under my Mickey Thompsons in the '68.
Pedestal rockers are in fact adjustable, but it's a PITA because they have to be shimmed. Studs are much easier to adjust, not to mention stronger. You'll need to pull the heads and have them modified if done the right way.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Dec 1, 2006
  • Dec 1, 2006
Pedestal mount roller rockers are "bolt" down style. Stud mount rockers on the other hand use studs that are already mounted into the head and lock nuts to hold them in place. If you are using stock heads, they are pedestal mount. You can have them machined for studs if you plan on upgrading to AFR, Edelbrock, or Trickflow heads, you might as well go with stud mount because these heads come machined for studs rather than pedestal mount.
bretamo
122
  • Dec 2, 2006
For my GT-40 heads, I picked up some Comp Cam conversion studs that allowed me to avoid the machine shop and put in steel stud mount Comp Cam rockers.
Engine Roller Rocker Stud Size, GT40P heads
  • foxbodyclark
  • Jan 25, 2025
2K
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Resolved Noisy Valvetrain
  • PonyGTrider
  • Jun 15, 2024
5K
Fox 5.0 Mustang Tech Jun 19, 2024
PonyGTrider
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
