Stud vs. Pedestal
  • Thread starter Thread starter myfirstii
  • Start date Start date Mar 16, 2004
M
myfirstii
401
chicago,Il.
Mar 16, 2004
  • Mar 16, 2004
Can Some One explain to me what is the difference between a stud mounted rocker arm and a pedestal mounted one. What does the stock 78 302 have?? Is it a stud? sorry if this is a really dumb question Maybe can some one post a picture of what they both look like ?? . Im currently in the process of rebuilding a 92 H.O for the II and im looking at getting either the AFR 185 or the AFR 165's heads and i need to know what would be the best bet the pedestal or the stud? What are the pros and cons of each of them? thanks for the help
Pat
T
THE COBRAMAN
pig 'rassler
1,974
Oklahoma
Mar 16, 2004
  • Mar 16, 2004
Stud type has the rocker retained on the stud by a nut over the fulcrum.
Pedestal uses a bolt down through the fulcrum.
A '78 302 would have a pedestal type head.
"Best bet" is going to be a matter of personal preference.
D
dmoody
789
Winston-Salem, NC
Mar 16, 2004
  • Mar 16, 2004
I'm pretty sure that AFR 185 and 165 heads all have studs. Studs along with roller rockers are the preferred method for high performance applications on a pushrod V8.
d
M
myfirstii
401
chicago,Il.
Mar 16, 2004
  • Mar 16, 2004
d
Thanks for the reply. I understnad now.
dmoody- both the AFR 165 and 185 let you choose between pedestal or stud.
Pat
98CobraClone
592
Ripley, Ohio
Mar 16, 2004
  • Mar 16, 2004
IMHO, I'd pull the valve covers and see what you have. If there's a nut that goes right through the center of the rocker arm, you have studs.
If you're planning a rocker change anyway (upgrade to 1.6 or 1.7) then I'd definitely go with stud mount.
jeffnoel
1,638
Clovis, CA
Mar 16, 2004
  • Mar 16, 2004
1.6 isn't an upgrade, that's the stock ratio.
77sleeper
GO BUCS!
7,266
Napalm, AZ
Mar 16, 2004
  • Mar 16, 2004
picture boy to the rescue, left is stud right is pedestal
98CobraClone
592
Ripley, Ohio
Mar 16, 2004
  • Mar 16, 2004
okay, when I was stating 1.6, I was implying 1.6 roller rockers.........
Z
zwhitr
847
Goldsboro, NC
Mar 17, 2004
  • Mar 17, 2004
For a minute there I thought we had a cheby guy lurking in our midst
1.5 is chevy OEM
M
myfirstii
401
chicago,Il.
Mar 17, 2004
#10
  • Mar 17, 2004
  • #10
thanks boys for the reply I appreciate all the help!~
Pat
P.S happy St. Pattys day!!!!!! Drink Up!!!!
Pat
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Should I Get a New Clutch Fork and Pivot Ball Stud?
  • AeroCoupe
  • Dec 18, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2022
96pushrod
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
