Studs snapped off in head.
  • Thread starter Thread starter BONE_STOCK
  • Start date Start date Aug 5, 2009
1 of 2 Next Last
BONE_STOCK
69
North Carolina
Aug 5, 2009
  • Aug 5, 2009
Welp...I was removing the stock headers and snapped two bolts on the passenger side. How do I go about removing the studs stuck in the head?
Thanks,
Mike
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Aug 5, 2009
  • Aug 5, 2009
cut a slot in them with a dremel or cutoff tool and you could try backing them out that way... soak them with some PB blaster before hand. Are they stock heads?
stykthyn
5,232
2,652
223
gainesville
Aug 5, 2009
  • Aug 5, 2009
soak them in pb blaster and grab them with vice grips
K
keiser blade
35
  • Aug 5, 2009
i would heat them as well
BONE_STOCK
69
North Carolina
Aug 5, 2009
  • Aug 5, 2009
No way to do that. The stud surface is in the head. Didn't come off right at the head of the bolt. Yeah stock heads.
whitesqual
235
Coeur D'alene, ID
Aug 5, 2009
  • Aug 5, 2009
Upgrade!
Get new heads!
BONE_STOCK
69
North Carolina
Aug 6, 2009
  • Aug 6, 2009
whitesqual said:
Upgrade!
Get new heads!
ha! not an option with this block!
ShortThrow50
923
Pa
Aug 6, 2009
  • Aug 6, 2009
Don't use easy outs either. You will wind up making the situation worse. Sounds like they are rusted in there pretty good. Your gonna have to either remove the head and take it to a machine shop to have them remove it or just not use that bolt hole. If you smear some permetex ultra copper on both sides of the gasket, you should be fine and not have any leak.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Aug 6, 2009
  • Aug 6, 2009
why isnt it an option?
stykthyn
5,232
2,652
223
gainesville
Aug 6, 2009
#10
  • Aug 6, 2009
  • #10
sounds like that head is going to have to come off
BONE_STOCK
69
North Carolina
Aug 6, 2009
#11
  • Aug 6, 2009
  • #11
Oy......why wouldn't an easy out work? I've never used one but it should work. Isn't that what those kits are for? lol!
I'd like to not have to remove the head. lol! Problem is that the bolts that snapped were on the same exhaust port. Good thing is that it's a BBK header so the pipes are stuck together with the plate. It may work without leaking if I tried putting the header on and used some RTV sealant. I think I'm going to try the easy out. Can't hurt more than it is right now.
90LxCoupe....it's currently not an option because when I do the heads...I'll be doing the whole nine yards. lol!
stykthyn
5,232
2,652
223
gainesville
Aug 6, 2009
#12
  • Aug 6, 2009
  • #12
easy outs are so hard they become brittle and often break off inside the bolt. drilling an easy out out(that sounds weird) of a bolt that it snapped off in is nigh impossible.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Aug 6, 2009
#13
  • Aug 6, 2009
  • #13
so how far in are the broke bolts? what have you tried so far to get them out, the RTV idea is most likely not gonna work.
BONE_STOCK
69
North Carolina
Aug 6, 2009
#14
  • Aug 6, 2009
  • #14
I'd say like an 1/8th to 1/4" in.
Brando5641
127
FT Gibson OK.
Aug 6, 2009
#15
  • Aug 6, 2009
  • #15
ez outs ALWAYS BREAKS OFF
i HAVE NEVER HAD ONE WORK.
There is no way of getting around it... It has to come off and go to the machine shop.
RTV or any of that other stuff is never going to work.
Its going to be more work trying to rig it than just sucking it up and pull it off.
DO NOT USE A E Z O U T. If you break it off you are realy screwd b/c u cant drill threw an ezout.
ShortThrow50
923
Pa
Aug 6, 2009
#16
  • Aug 6, 2009
  • #16
it will break off. they work for some applications but not for old rusted bolts that have been in a block for years. If you are serious about using an easy out, dont say i didnt tell you so. Its just gonna cost you more for the machine shop to remove it becuase now you have a broke easy out in there.
Beasty306GT
671
Oxford,Mass
Aug 6, 2009
#17
  • Aug 6, 2009
  • #17
ur gonna have to pull the head and drill it out
BONE_STOCK
69
North Carolina
Aug 7, 2009
#18
  • Aug 7, 2009
  • #18
oy....this sucks.
slp352
42
Peoria,IL
Aug 7, 2009
#19
  • Aug 7, 2009
  • #19
This just happened to me with a water pump bolt in the block. We used an easy out on it but we did it very slowly and took it easy with it. We managed to remove the bolt and now life is good again. Like they said above you don't want to break the easy out in the head.
BONE_STOCK
69
North Carolina
Aug 8, 2009
#20
  • Aug 8, 2009
  • #20
Yeah....I think I'm gonna try the easy out. I'll just drill a big hole on the stud to use the biggest easyout I can find. If it breaks off in the head then I guess it's time for an upgrade!!
1 of 2 Next Last
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Snapped off ECT when trying to remove.
  • 88VertFox
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
88VertFox
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
