Stupid E-brake quetion
  • Thread starter Thread starter super302
  • Start date Start date Jun 8, 2005
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Jun 8, 2005
  • Jun 8, 2005
My ebrake handle isn't "Parallel with the world", it 'favors' the drivers side, is there any adjustment in there to get it back even with the counsel??
BTW-i can push it over to make it straight, put it'll jsut slide right back over, it isn't that bad, but i'm really picky about my car
Does anyone know what i'm talking about
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 8, 2005
  • Jun 8, 2005
I just put a handbrake in my car yesterday, the front bolt hole is slotted left and right and the rear bolt hole is slotted front to back so yes there is some side to side you can get out of it.
super302
May 29, 2004
2,878
Davenport, IA
Jun 8, 2005
  • Jun 8, 2005
do i need to rip out the center counsel?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 8, 2005
  • Jun 8, 2005
Yep, the arm rest first, then pull up the shift boot, and take out the 4 screws and lift the console up. The hardest part is the damn plug for the power mirrors, I can tell you that plug wouldnt vibrate loose in an earthquake!
super302
May 29, 2004
2,878
Davenport, IA
Jun 8, 2005
  • Jun 8, 2005
Thanks
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 8, 2005
  • Jun 8, 2005
No Problem!
super302
May 29, 2004
2,878
Davenport, IA
Jun 8, 2005
  • Jun 8, 2005
can you tell me what one i need to mess with:
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 8, 2005
  • Jun 8, 2005
The forward hold down bolt is slotted left to right, so that would be the one to help you straighten from side to side.
super302
May 29, 2004
2,878
Davenport, IA
Jun 8, 2005
  • Jun 8, 2005
i messed with both bolts, sorta worked, still not perfect....oh well
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 9, 2005
#10
  • Jun 9, 2005
  • #10
You could always take it out and elongate that front hole a bit more to get it pointing straight.
N
nmk_61802
61
#11
  • Jun 10, 2005
  • #11
I think this needs to be looked at again, as mine is the same way. I don't think it's fixable by adjusting the handle position. On mine the handle will wiggle when the e-brake is not engaged, but the base will not move, nor will the handle move when the e-brake is engaged and has tension on it. It appears as though the center pivot section has a hole that wallers out and causes this problem. The only way I know to fix it is to replace the handle. If anyone else knows better please correct me as I do not want to replace this.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 10, 2005
#12
  • Jun 10, 2005
  • #12
To stay somewhat on topic...but what is the way to know if my e-brake is shot or if it just needs to be adjusted...
My cable pulls up all the way up and doesn't hold the car...but the cables aren't snapped from what I see...???
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
C
Progress Thread 2004 Comp Orange GT
  • ctandc
  • Jun 26, 2023
  • 2 3 4
6K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
ctandc
C
