Stupid E-brake quetion
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
My ebrake handle isn't "Parallel with the world", it 'favors' the drivers side, is there any adjustment in there to get it back even with the counsel??
BTW-i can push it over to make it straight, put it'll jsut slide right back over, it isn't that bad, but i'm really picky about my car :D
Does anyone know what i'm talking about :shrug:
I just put a handbrake in my car yesterday, the front bolt hole is slotted left and right and the rear bolt hole is slotted front to back so yes there is some side to side you can get out of it.
Yep, the arm rest first, then pull up the shift boot, and take out the 4 screws and lift the console up. The hardest part is the damn plug for the power mirrors, I can tell you that plug wouldnt vibrate loose in an earthquake!
Thanks :nice:
I think this needs to be looked at again, as mine is the same way. I don't think it's fixable by adjusting the handle position. On mine the handle will wiggle when the e-brake is not engaged, but the base will not move, nor will the handle move when the e-brake is engaged and has tension on it. It appears as though the center pivot section has a hole that wallers out and causes this problem. The only way I know to fix it is to replace the handle. If anyone else knows better please correct me as I do not want to replace this.
To stay somewhat on topic...but what is the way to know if my e-brake is shot or if it just needs to be adjusted...
My cable pulls up all the way up and doesn't hold the car...but the cables aren't snapped from what I see...???
