Stupid Question?
I've played around with my tweecer rt to get a better idle, remove smog, etc. But I was wondering, how do I know what changes to make? I've datalogged a few times but what do I do with it then? Does the tweecer suggest changes to make or do I need to review each datalog with a fine tooth comb and adjust from there?
I currently don't have a wb o2, but am waiting on my DIY wb o2 from www.14point7.com
I use BE and EA instead of Caljunk.
Maybe I'm an idoit,
Adam
Take a look at what I had posted on eectuning http://eectuning.org/forums/viewtopic.php?p=53686&highlight=#53686
I guess I just haven't played around enough with the tweecer to get EA to suggest a tune/change. I imported datalogs but didn't really see what to change, scalars?, not sure what I am supposed to change. When entering hp and all the info I have into the one tab (not on the laptop with BE and EA at the moment) all the numbers were skewed.
Adam
Adam,
I scanned through the eectuning thread....
EXACTLY what changes have you made to the .bin file? (you should be keeping a list of all the parameters you are changing...)
Are you using CalEdit to load a file to the tweecer?
I guess I'm not really sure what you are asking...
do you want smoother idle?
more power?
better economy?
etc.....?
jason
Better economy is what I'm shooting for as a starting point. I'd like to really know how to use the tweecer before I put my 351 in the car. I've got the list of what I changed at home, at work right now.
I guess I didn't really see the tweecer suggesting any changes, just wondered where I should look.
No I'm strictly using BE and EA, no caledit or calcon.
Adam
Adam,
When you get a chance post up your current tune changes.
Look into the DFSO (Decel Fuel Shut Off) settings for some mpg improvements.
As a starting point you can copy the DFSO scalars from the X3Z tune.
I had to tweak my DFSO settings a little before I was happy with it, but the X3Z settings were fairly close...
That should help a little, but I am assuming you have already gone through the MAF Transfer and Injector Slopes/Offsets..........
jason
I'll have to fire up my laptop when I get home tonight. I've loaded the W4HO (95gt) transfer for the MAF but haven't messed with the injector slopes/offsets, not really sure what to do with those, still have the stock 19#'s. Fuel Pressure is at stock setting.
What I've done so far.
-Compensated for the 80mm TB (overkillf or now, long story).
-Loaded 95 GT MAF Transfer.
-Disabled EGR
-Added timing in the WOT vs Advance section. 6deg is added starting at 3k or 3500, can't recall at the moment.
-Adjusted Idle slightly.
-Disabled the CEL.
-Moddified the rev limiter to around 6k and 6500, can't recall for sure at the moment.
-Removed the speed limiter which never seemed to work before.
Thats about all I can think of at the moment. Just trying to get prepared before spring, car has been stored since end of November.
I used to run my car at 16deg advanced by adjusting the dist. When I got the TwEECer, I set it back to base and only used the ADV. vs WOT.
I appreciate the time you've take to answer my posts.
Adam
I found out what is causing drivablility issues. i.e. sudden loss of power like the motor is flooding with the throttle body fully open. My logs show the ECT going to -246 and ACT to -60 (or similar). Not sure why this is happening but when I go back to the #5 position (tweecer bypass), everything is fine.
I double checked my settings.
- disable cel/egr/speed limiter
-95gt maf transfer loaded.
-ADV vs WOT is increased from 3500rpm on up a total of 4 degrees.
-.72 TB airflow, based on datalogging for two minutes with the iac unplugged and then averaging the outcome.
I even loaded a strategy from a 95 gt on position 2 to clear things out. Put the switch to pos. 2, turned key on, waiting 10 seconds, pump ran continously, turned car off, put the switch back to pos. 1 and started it.
That's all I've done so far.
Adam
Adam,
I don't want to seem like I am shrugging you off, but I'm not sure what to do with your ECT/ACT issues.
There have been some weird things reported with CalCon an BE (older versions of BE, I think Clint fixed something recently...).
Check out EECTuning.org
(if the site ever comes back up....)
jason
Adam mentioned something about deleting the CEL, what is that?
One more thing I was curious about was TB air flow. How important is that? i have HCI but my TB flow is stock and my car kicks over and idles surprisingly well. Every time I have messed with it, my idle gets twacked out.
thanks
Eric
Eric,
I assumed Adam was disabling the emissions junk to 'delete the CEL'.........
I don't think I ever got around to changing the TB Airflow on my tune...
My 408w with a 70mm TB idled ok...
With your stock TB you shouldn't really need to, but it may be interesting to check anyway.
jason
