Styled Steel Wheels and Brake Swap?
To my knowledge the center hub on the granada is bigger than the early stang and the SS wheels will not fit. You might be able to get the wheels machined to fit.
Also if you have wheels for drum brakes and then go to disc I know for sure that the wheels will not fit unless you grind a good amount of the caliper down to clear the inside of the rim.
Hope this helps.
