Sub-frame connectors?
2BADSTANGS
385
Colorado
I am thinking about adding sub frame connectors to the '93. My question is wich ones are the best "bang for the buck"? Also to those of you who have added them, what kind of difference did you notice after the install? Thanks!
easy
#1 Maximum Motorsports full length professionally welded in.
#2 Huge difference. Less rattles, more solid feel in hard cornering, more power to the ground, car breaks lose at lower rpms than before.
Go with full-lengths, or fugeddaboutit.
Lots of different companies offer full-length SFC's, so take your pick. Maximum Motorsports seems to get a lot of votes. Wolfe Racecraft (I think) has some Über-hardcore ones that go through the floorpan in the back and involve some cutting, but those are kind of overkill for most cars.
My car has a set of the OLD style, basically a section of pipe with 2 flanges on each end. I had them welded in back in the day when you couldn't find anyone to work on these cars and the welder didn't have a lift so he jacked one side of the car up at a time and welded them in that way. Hindsight is 20/20 so when I think about it I cringe, so now I have a set of MM full length connectors on the way.
I don't remember the connectors I have making a huge impact in the way the car rolled down the road, but I can't say they were installed the right way either.
