Subframe Connectors
foxbobby
36
18
28
Indiana
I'm thinking my 90 convertible is way past due for subframe connectors, looks like full length and weld on is the way to go. Market has several brands to choose from and all seem affordable, looking for suggestions from my peers.
maximum motorsports. Period.
Weak Sauce....
Kenny Brown Extreme Matrix SF connection system. Period, Exclamation point.
There simply isn't a better subframe system out there than this. One weanie piece of rectangular tubing w/ a seat brace reinforcement pales to this system. Once installed, the car can be jacked up anywhere along the entire side of the pinch weld. The effective cross sectional area of reinforcement is equivalent to 12" wide instead of 2".
A Ladder will always be a stronger frame reinforcement than a bar anyday.
I have a homemade version of this system under my car. You can literally place a jack under the pinch weld, and the car is so rigid, the entire 2/3rds of the car lifts up when you raise it.
The jack is all that is supporting the car.
Stifflers has the best system I know of for a convertible. It can be found at BuyStifflers.com.
I saw the system at Mustang Week. They literally had the front corner of the under body jacked up to the point that both front wheels were off the ground. They then opened and closed both doors effortlessly. No chassis twisting at all.
If I had a convertible their system would be on my car....I have a notch back now so...regular full lengths with seat braces for me.
Reactions: Davedacarpainter
Weak Sauce....
I gotta to admit Mike, your rear end still gets me all a flutter.
There you go @Noobz347
Reactions: General karthief
Looks like Kenny Brown & Stiffers are both heavy duty. My girl lives a pampered life, weekends at church not the strip. Thinking Maximum Motorsports makes sense for this weekend driver. Thanks for the advice & Mike be careful not to bend over when Dave's around :)
Oh Mike already knows that after my visit to Alabama....
I was looking at the Stiffler's kit for my convertible, they say "NOTE: On ‘79~’93 convertibles the Stiffening Rail is not required" I would think that since it is a convertible you'd want the stiffening rail. Or is there something I'm missing?
Weak Sauce....
didnt know Kenny brown was still around. that all we use to use back on the 03 cobras back in the day
