  • SN95 4.6L Mustang Tech
Subframes on a vert?
  • Thread starter Thread starter BlackBadGT
  • Start date Start date Mar 14, 2004
1 of 2 Next Last
BlackBadGT
323
Pickerington, Ohio
Mar 14, 2004
  • Mar 14, 2004
Are the underbodies on the convertable GT's the same as the coupes? I pull a wheel on my launches, and it is most likely to chassis twist. I would like to add some rigidity before i damage the car. I was eyeing the steeda full length subframe connectors. http://steeda.com/store/-catalog/FullLengthSFC.htm Will they fit my 2000 GT vert? Anyone else have any other SFC reccomendations?
00BlackBeautyGT
298
E.S. Long Beach, CA
Mar 14, 2004
  • Mar 14, 2004
Maximum Motorsports. Period. I have a 2000 Vert like you and MM is what I have. One of the best mod I've done so far.
Check this thread out -
http://forums.stangnet.com/showthread.php?t=417436
GOLDENPONY
1,503
LOVELAND, OHIO
Mar 14, 2004
  • Mar 14, 2004
Subframes
I have KB on my 2000 'vert and am well pleased with them. The car came with subframe connectors from the factory but they were really cheesey. I noticed a nice improvment in the way the car feels when driving. I also recommend strut tower braces for anybody with a convertible.
BlackBadGT
323
Pickerington, Ohio
Mar 14, 2004
  • Mar 14, 2004
Where did you get your MM subframes?
K
kennym01
343
  • Mar 14, 2004
I will be going with maximum motor sports as well for my 01' vert...$79.00 for steel/$109.00 for powder coated black...
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Mar 14, 2004
  • Mar 14, 2004
Those price are for standard right? Why don't you go with the full length Subframe?
http://maximummotorsports.com/sfc.asp
Bone Racing
1,075
Long Island, NY
Mar 14, 2004
  • Mar 14, 2004
full lengths or nothing
01mgvert
302
  • Mar 14, 2004
Full Length Subframe Connectors
I recently had Steeda full length subframe connectors welded to my 2001 GT Vert. It really strengthened the underbody. When I hit potholes now, my interior doesn't rattle. I plan to install a Steeda strut tower brace next week. I may then order the Steeda 4-point rollbar.
'03Vert
20
  • Mar 14, 2004
'03 'vert -- I went with Kenny Brown subframes and jacking rails so I could also use their diagonal braces (can't remember the trade name) which connect and triangulate the subs with the jacking rails. Noticable stiffness improvement, plus I can now put a jack under the car just about any place that's convenient. Maybe overkill for a pure street car, but better over than under in my book
MT1083
1,033
Charlotte, NC
Mar 14, 2004
#10
  • Mar 14, 2004
  • #10
I am getting ready to install my full length subs. They are MM and I think the sfc's are the same on my model for coupe and vert. Call them up to make sure.
01SLVRGT
201
Macon Georgia
Mar 14, 2004
#11
  • Mar 14, 2004
  • #11
Maximum Motorsports Full lengths
pinski
710
North Carolina
Mar 14, 2004
#12
  • Mar 14, 2004
  • #12
where did you guys go to get them installed? also, how much installation set you back. This is one mod I've wanted to do for some time, but have never gotten around to it...
Xanax
103
#13
  • Mar 14, 2004
  • #13
I agree Maximum Motorsports Full length
K
kennym01
343
#14
  • Mar 15, 2004
  • #14
My mistake, $119.00-$149.00 for full length subs. I will be going with full length for sure. Otherwise why bother...
brian98gt
377
new jersey
Mar 15, 2004
#15
  • Mar 15, 2004
  • #15
[QUOTE='03Vert]'03 'vert -- I went with Kenny Brown subframes and jacking rails so I could also use their diagonal braces (can't remember the trade name) which connect and triangulate the subs with the jacking rails. Noticable stiffness improvement, plus I can now put a jack under the car just about any place that's convenient. Maybe overkill for a pure street car, but better over than under in my book [/QUOTE]
i have the kb super subs and i was thinking about the jacking rails and extreme matrix cross brace. i had the subs welded in, but i'm not sure if the jacking rails and cross brace could just be bolted till i find someone to weld for me. did u have them welded? or can you bolt them for now and have them welded later?
BLKVERT
407
SATX
Mar 15, 2004
#16
  • Mar 15, 2004
  • #16
I have Kenny Brown Super Subs as well...I think Subframes are good investments irregardless of whom they are made by. Get'em.
NasaGT
1,993
Virginia
Mar 15, 2004
#17
  • Mar 15, 2004
  • #17
I've got M&M full - lengths. No matter which brand you get, get the full-length versions. You'll still get flex with the shorter ones.
'03Vert
20
#18
  • Mar 29, 2004
  • #18
[[I have the kb super subs and i was thinking about the jacking rails and extreme matrix cross brace. i had the subs welded in, but i'm not sure if the jacking rails and cross brace could just be bolted till i find someone to weld for me. did u have them welded? or can you bolt them for now and have them welded later?]]
I had mine welded at the same time when the subs went in. Not sure about whether bolting is reasonably feasible, but let's put it this way: I wouldn't bolt them in, as there's a lot of floorpan to be spanned/supported, and I'd want to make sure the load is well spread out over several welds rather than concentrated at a couple bolts.
brian98gt
377
new jersey
Mar 30, 2004
#19
  • Mar 30, 2004
  • #19
[QUOTE='03Vert][[I have the kb super subs and i was thinking about the jacking rails and extreme matrix cross brace. i had the subs welded in, but i'm not sure if the jacking rails and cross brace could just be bolted till i find someone to weld for me. did u have them welded? or can you bolt them for now and have them welded later?]]
I had mine welded at the same time when the subs went in. Not sure about whether bolting is reasonably feasible, but let's put it this way: I wouldn't bolt them in, as there's a lot of floorpan to be spanned/supported, and I'd want to make sure the load is well spread out over several welds rather than concentrated at a couple bolts.[/QUOTE]
thanks, i guess i'll just wait till i find someone that can weld before i get the other components.
Chipster
15
Woodstock, GA
Mar 30, 2004
#20
  • Mar 30, 2004
  • #20
1 of 2 Next Last
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
West Coast Performance Shops - San Diego, CA
  • gkomo
  • Dec 16, 2024
  • Regional Forums and Event Information
2K
Regional Forums and Event Information Jan 27, 2025
93Nifty
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
