Success with header wrap? Or get starter shield? (to help hot start w/ longtubes)
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Well what are you all's "success" stories with header wrap? Does it work? Is it self "sticking"? Will it hold enough heat in away from the starter or would a starter shield be better? I think header wrap would be a cleaner look but what do you guys think?
I don't want to apply it and see that it doesn't help the starter act "normal"?
Thoughts?
I have bassani ceramic coated 1 7/8" long tube headers on my '90 GT and i decided to change the starter b/c it would have been very tight w/ the big diameter long tubes.....i bought the Powermaster mini-starter for like almost 300 bucks.....
it's hilarious, my starter has more torque than some stock honda civics, the starter has 90lbs/torque....lol
The looks isn't what bother me because the header wrap would be cleanly wrapped agaisnt the header and not visible. I just don't like the "clutter" of a shield?
I might go with the shield though...suggestions?
You wouldn't need much to make a shield.
Header wrap works but it also traps moisture against the header and wrap causing premature deterioration of your nice Long Tubes.
Do you currently have a Mini-starter? If not, it might be the best solution all be it, the most expensive.
I don't have the money for a ministarter.
They make velcro wraps for the starters Baxter. I just wanted a cleaner look.
Now with the header wrap I was going to install it with the longtubes off the car and wrap if flat/clean/dry. But the question is, does it provide enough heat protection?
I really don't want to tear it off later to find out, you know:shrug:
Thanks guys!
Well I was just wanting to put the header wrap in the "starter area"...not the entire header. Thanks for the reply...I wasn't being "smart" with you. Just saying I didn't have the money to spend on a mini-starter.
NO... you misunderstood my post. I wasn't trying to come off as a smarta$$ either. (Sorry about that) Sometime when I type, my brain tells me that I have a complete sentance when I actually leave out things.
OK... should have been, It's OK. [meaning, I am in the same boat as you]
Sorry about that...
Header wrap locally is a new idea I haven't though of. The long tube headers pass closer to a stock starter reducing the amount of air gap (air insulation) between the starter and header. With the reduced insulation, the heat from the header is then pulled into the starter body (heat energy transfers from a hot object to a cold object) The added heat in the starter body builds up in the electronics / wiring which reduces the wires abiltiy to move current from the battery to the starter motor.... This is heat soak. If you insulated the headers in the proper location (the side facing the engine) you should beable to deflect the heat away from the starter and return the air insulation back to a near stock condition.
Alright cool:nice:
I'm just wondering if header wrap in that centralized area will hold the heat in (away) enough. I guess if I wrap it enough it will work, right?
Is it self sticking or how does it apply to the ceramic coating?
In theory it will work. I am unsure of how much you will need to add though... You will have to experiment.
Last time I used header warp (almost 10 years now) I had to clamps to hold it in place. Metal bands similar to hose clamps. I don't know if they have a glue that will hold up to the temps of a header.... But tonight I can look
You can buy starter rap blankets thet are made out of a big pices of header rap.
I did this on my car and it worked wonders on the hot start issue.
I think i paid 25$ for it a while ago form summit.
5spd GT btw what does your car run in the quarter ?
Grn92LX said:
You have a 93, they come with mini starters from the factory :cool: 92+ cars have stock mini's.
I was thinking of hightorque ministarters - not stock replacement. I'm aware of those.
Anyways mat50ho - My engine is shot (no oil pressure) so no quarter mile times:) I ran 8.4x in the 1/8th mile at 86.4x mph with some things wrong. But we all say that right...
Thanks for the replies guys!
