I've already figured out that I want to do engine work before I get a supercharger because I can do that in steps, instead of spending around $4000 for the supercharger and having to install it all at once. I want to get a cam and get the upper and lower intakes and the heads if possible, port and polished. But because I would be doing that before the supercharger, I don't think the pistons and stuff could handle the power after i put that on. I know it says around 300 (rw?)hp with maybe an exhaust, so adding a cam and some port and polished stuff might make that a little higher, too high for the stock pistons and rods.
So i'm trying to figure out what order to do everything, and specifically which items to get. In another post i've found that a 207*/215*, .493"/.495" lift, 112-114LCA cam is probably good for my application because I live in San Diego with stricter emissions, and I'll be going with procharger later. When I get the cam installed by a shop (i dont' know how long it would take me to do it, and I would have to have my car, winter break is only so long) should I have them put in the pistons and rods, if it is even recommended that I get them. I figure the engine will be half apart for the cam install, why not trade pistons. If getting pistons are recomended, which ones are recommended (flat top or dished, and company), I'd like to keep stock compression, or maybe a little less because of the supercharger.
I figure i'll get a chip when I get the cam so that it can correct the timing so that I can pass emissions, so i'll probably get a ford chip that I can get reprogrammed when I get the supercharger. And when I get the cam, what else will I need, I'm expecting to need springs and possibly new lifters, and if I do, which ones would I need.
Will I need new head bolts after the head's been removed. I think i heard that only certain block types, depending on what type of metal they are, need new ones once they've been removed because they stretch or somethign. What type of block do we have?
I want to get an 8.8 rear end either with stock gears or 3.73s if they come with them.
I have a 99 v6 5speed 30,000 miles with true dual exhaust and an ebay intake, whick I know i'll need to ditch when i get the supercharger. Thanks for any future help
