Anyone knows who manufactures this cam for sumit? I am looking for its performance curve (torque vs RPM) and cannot find any similar cam. Is it likely that it makes at least the same low end torque as stock ford cam (with dual plane manifold and 600 cfm carb)? Is it suitable for quite a low ratio (3:1) at rear axle?
('73 sbf 302)
specs:
Duration at 050 inch Lift: 218 int./228 exh.
Advertised Duration: 276 int./286 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.471 int./0.471 exh. lift
Lobe Separation (degrees): 114
('73 sbf 302)
specs:
