summit balancer question
  • Thread starter Thread starter stykthyn
  • Start date Start date Apr 13, 2010
stykthyn
5,232
2,652
223
gainesville
Apr 13, 2010
  • Apr 13, 2010
I just recieved this balancer from summit
Summit Racing SUM-163302 - Summit Racing® OEM Harmonic Dampers - Overview - SummitRacing.com
Its one of the last things I need to put on to button up my engine build. My problem is that it has three sets of timing marks on it. Does anyone know which ones I need to use?
stykthyn
5,232
2,652
223
gainesville
Apr 13, 2010
  • Apr 13, 2010
no one has used one of these?
poulrais
44
Sherbrooke. Quebec, Canada
Apr 13, 2010
  • Apr 13, 2010
Here are Summit's instructions:
http://static.summitracing.com/global/images/instructions/sum-163289.pdf
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Apr 13, 2010
  • Apr 13, 2010
I'm just spit balling here, but didn't the timing pointer change locations on the 302 engine over the years (pre-5.0 days)? It may be for that.
Can you just turn the engine over until the number one piston is at TDC on the compression stroke and put the balancer on and see which set of timing marks is closest to 0 degrees?
Edit: I see it basically says that in the instructions. There ya go.
Tanus
847
A to the Z
Apr 13, 2010
  • Apr 13, 2010
what he said ^, just put #1 at TDC,CS, then put it on and one set should line up. Its like that cause different sbf motors have different pointer locations
stykthyn
5,232
2,652
223
gainesville
Apr 13, 2010
  • Apr 13, 2010
where did you find the instructions?
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
