Alright well... first off the fit is alright I suppose.. they are not direct replacements for the 94-95 mustang (or really any mustang). They are a standard "FORD" replacement aluminum radiator. The quality is pretty great IMO. I've had it for 8 or so months and I haven't had a single problem with it yet. My main complaint is that they do not have a drain plug so be prepared to either disconnect the lower radiator hose, or siphon the coolant out (this is what I do, much easier
) The main problem with it is that the original radiator mounts don't work for it. If you search hard enough you
might be able to find a post by somebody who flipped one of the mounts around and was able to use it ... I'm not so sure.. all I can tell you is what I did.
Let's see... no real special tools were required. For installation I removed the battery and battery tray - disconnect the CCRM and put the aside, remove overflow bracket and tank, remove radiator. If you have A/C the line will be in the way... but you can work around it. Basically just drop the new guy in and begin mounting it. What did I do? I used heavy duty zip ties. Sounds ghetto but worked like a charm. Once you get the radiator in you need to get the fan on there somehow.. i used zip ties! go figure. I had to trim off a chunk of the plastic with a hacksaw to get it to fit.. I cut off some on the drivers side of the fan and moved it over towards the drivers side. This is so it would clear the overflow tank.
I couldn't keep the CCRM mounted to the overflow bracket so I just set it aside and ZIP TIED it to some harnesses.
I bent the overflow bracket slightly to push the tank against the radiator to act as another mount. umm that's basically it or that's all i can think of right now.
i did it one evening after work in my driveway.. shouldn't be hard at all.
oo another thing is they don't come with a nipple for the overflow tube to plug into the radiator so I had to buy nipple thingy that screws in ... check the pictures - i have a picture in there somewhere.
http://webpages.charter.net/forestrat/mustang/radiator/ <-- pictures
SUM-380425 Ford: 25 3/4 in. x 19 in. $169.95
SUM-380428 Ford: 27 3/8 in. x 19 in. $169.95
SUM-380431 Ford: 31 in. x 19 in. $179.95
I got the 31 in. x 19" one
Any questions?
