5spd - If it's not fuse 8 as stated above, unscrew the sunvisor brackets from the headliner and lower the sunvisors (the wiring will have a small amount of slack). There will be a connector there that resides up in the headliner, make sure it hasn't become disconnected. While you're at that connector check for 12 volts while it's apart (it should be hot all the time).
You should be able to do basically the same thing for the lumbar air pump motor.
