Super charger?
  • Thread starter Thread starter bynummustang
  • Start date Start date Sep 1, 2005
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Sep 1, 2005
  • Sep 1, 2005
1990 LX 5.0 Hatch with 5-speed: mods below.
Which type and company supercharger works best for just a daily driver, not weekend warrior?
Roots syle/twin screw or centrifical(spelling)?
I want a super charger, but I also want a good head, cam, and intake. But also want a stroker...so I'm stuck.
Please no full-out-war...
D
dead
43
Mississauga, Ontario
Sep 1, 2005
  • Sep 1, 2005
Well daily driver vs weekend warrior is generally useable torque vs high horsepower. In that respect a roots or lysholm blower would be best for a daily driver, as you get all that extra power all throughout the rpm range rather than more top-end pull. However, aside from the Powerdyne, I think they're all pretty expensive. For a daily driver I'd recommend just a Novi 1000 or Vortec A-Trim or something.
If your car's a daily driver, why not start with H/C/I, see how that is, get a small blower if you want the additional power.. I wouldn't go stroker but that's just me, if you're looking at a new shortblock I'd do 306.
5.02GO
308
Ky, Blue Sky Country
Sep 2, 2005
  • Sep 2, 2005
Go with a supercharger first. It is possible to have that thing installed, up and running with in 4 hours.
Check out these links....
www.superchargers4less.com
www.superchargersonline.com
and another.......
www.superchargerhelp.com
Enjoy.......
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 2, 2005
  • Sep 2, 2005
If you have a good tuner get a supercharger from Vortech (S/c or S trim).
If you don't have access to a good tuner I would get a h/c/i package with the supporting parts. Easier to tune and your "rebuilding" the top half of the engine while your doing it.
A supercharger has more "rotating" parts to go wrong and complicates things when something goes wrong on your car. More to "look into" and pull when you replace something.
It isn't going to take a newbie 4 hours to put on a supercharger correctly.
Lyncher
434
  • Sep 2, 2005
a KB 1.5 would be a nice choice with power throughout the rpm rang...but it is definatly too small for a stroker...
M
macx
228
SE Missouri near Cape Girardeau
Sep 2, 2005
  • Sep 2, 2005
The roots or screw type will definitely give you more throttle response off-idle and well up into mid range, therefore IMHO more "streetable". However, they might be a bit more expensive.
The Eaton brand roots would probly be the least expensive, but somewhat less effective as you get into upper mid range rpm ranges than a Kenne Bell or Whipplecharger screw type.
Just a suggestion - you might be able to find an Eaton take-off cheaper from someone upgrading a Cobra or Bullit Mustang from the stock Eaton to a screw type. Maybe advertise on the various Mustang board classifieds, and do a search on ebay - you can post a long term search on ebay & they'll notify you if one comes up for sale.
One last thought - I don't know if one off a TBird SuperCoupe V6 would be big enuf, but you probly could find one of those fairly cheap at a salvage yard. You can always "cheat" a little bit on those blowers by speeding up the pulleys by going bigger drive or smaller driven size.
M
macx
228
Sep 2, 2005
  • Sep 2, 2005
Just did a quick search on Eatons - the Supercoupe has an M90 which Eaton's site lists as for 3.0 to 5.0 car engines.
Here's a couple other links
www.magnusonproducts.com/reman.htm they rebuild them
and
www.usedsuperchargers.com
STANGateURlilSS
716
USA & SANDBOX
Sep 2, 2005
  • Sep 2, 2005
I Would Go Roots Style For The Supercharger.. As They Produce More Torque And Hp Lower In The Rpm Range Where You Will Use It On The Street As With A Vortech.. At Higher Rpm..
ALTHOUGH A H/C/I COMBO WOULD ALSO BE A NICE WAY TO GO.. AS STATED EARLIER IN THE POST.. YOU ARE REBUILDING THE TOP HALF OF THE MOTOR.. WHICH IS ALWAYS A GOOD THING.. AND LATER DOWN THE ROAD YOU CAN GET A BLOWER AND THE TOP HALF OF THE MOTOR IS READY..
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Fox What Do You Guys Use Your Car For?
  • bleedinggreen
  • Jan 31, 2024
  • 2 3
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 22, 2024
Rdub6
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
