  • SN95 4.6L Mustang Tech
super lean AFR/bogging/lost power
  • Thread starter Thread starter the98stang
  • Start date Start date Oct 24, 2007
the98stang
2,408
Clovis, CA
Oct 24, 2007
  • Oct 24, 2007
Ok I changed my plugs a few days ago and I got on it today and in the upper RPM's it bogged down. It felt like it was missing. I heard a ticking noise, but it didn't sound like a ping. My last fill up of gas was some cheaper 91 octane gas (Valero), but usually my car runs fine with that gas. My AFR is REALLY lean, like 12.5-13 AFR in the upper RPM/high load. So wtf can cause such a huge lean spike all of the sudden? Maybe I got a bad batch of gas? It'll build boost but then all of a sudden it'll loose tons of power and sort of 'bog'. How should I try and fix the problem? Any opinions are appreciated. Thanks!
Tanner
D
Disturbed One
191
  • Oct 25, 2007
I don't know much myself but maybe try adding some kind of octane booster or some higher rated gas to see if there's been a switch with all the additives that are put in the gas??
twogts4us
4,188
12
79
Dunedin, FL
Oct 25, 2007
  • Oct 25, 2007
I trust you properly gapped the new plugs for your blown application....?
Otherwise, did you fail to re-hook-up a hose or something, allowing additional, un-metered air in?
hotstang_46
481
Charlotte NC
Oct 25, 2007
  • Oct 25, 2007
I'll preface by saying I'm no mechanic....... but when my car started bogging in upper rpms it was driving me nuts figuring it out....
I ended up replacing the fuel filter, fuel pump filter, and the filter on the canister the fuel pump sits in........ then she cleared right up....
hope that helps!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 25, 2007
  • Oct 25, 2007
have you changed the fuel filter?
what plugs did you put in ?
what did you gap them at ?
check engine light ?
I see you have the pro racer package have you done anything different on the tune ?
have you cleaned the MAF ?
lots of variables to go over
the98stang
2,408
Clovis, CA
Oct 26, 2007
  • Oct 26, 2007
I'm beginning to think un-metered air is getting in. I'm going to reposition the intake a little. I did mess with the intake when replacing the plugs. My fuel filter is fairly new. I gapped the NGK BR7EF plugs to .033 and torqued them to 13lbs. I do think there is a vac leak though. I just noticed the idle was at 1100 RPMs the other day. But it was weird because it wasn't always at that RPM when I came to a stop. I'll check the connections and report back.
Venom_Nitrous
416
Spearfish, SD
Oct 26, 2007
  • Oct 26, 2007
did you put the maf back the EXACT same way?
the98stang
2,408
Clovis, CA
Oct 27, 2007
  • Oct 27, 2007
I never reclocked the MAF. Anyway, I fixed the problem. When I changed the spark plugs I had to remove the intake, and when I did so, I guess I installed it incorrectly and extra air was escaping causing a vacuum leak. So I made it a more tight fit and she runs great
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
F
Fox Fuel or spark issues?
  • Frank cortez
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
AeroCoupe
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
