  • 2005 - 2009 Specific Tech
supercharger and spark knock
  • Thread starter Thread starter gpp
  • Start date Start date Dec 22, 2010
G
gpp
137
  • Dec 22, 2010
let me see if i have this kinda straight.on a sc motor spark knock is the main killer of motors.next would be a lean fuel mixture.so,if you retard timing enough to prevent spark knock and make sure you have plenty of fuel you stand a good chance of running a motor up to about 480 rear wheel hp without breaking a rod or piston.i know there is no guarantee on this what so ever,but if you run a very safe tune your chances are better than running one as close to the edge to get that last hp.i really love the so call mid throttle response after raising my boost from 9 to 14 lbs but dont want to risk breakage.if i give up a little top end hp thats no problem.so,does my theory sound logical or am i crazy and need to build a stronger short block.
midlifeGT
9
cincinnati
Dec 22, 2010
  • Dec 22, 2010
All signs point to stroker short block. Many of the higher end speed shops recommend the improved lower end when taking the 3 valve 4.6L above the 10-12 psi mark (based on intercooled twin screw SC), or 450 lb.ft Torque (RW) according to my North Webster, Indiana sources.
$3300 gets you a very nicely designed 5.0 Stroker short block with all forged internals from these same folks. They have always done me right.
Keep in mind that the 3 valve lower end was not built with the same thought process as the 03-04 4V 4.6L Cobra Terminator engines which had a lot beefier lower end and could handle a heck of a lot more HP and Torque.
I am running 7psi on a Saleen Twin Screw and stock engine currently and will be updating fuel (volume) delivery (already have 39# injectors), cams and LT's this spring but have no further plans at this time to go the next stage (8-10 psi) until I get the money together to go with a stroker block. This will likely put me just under the 450 Torque limit (currently 407-409 T). I may even hold off on one or the other to play it safe. Nothing like a car sitting in the garage broken that you are still making payments on.
Have a Merry Christmas.
G
gpp
137
  • Dec 23, 2010
mine is a saleen also with kooks long tube sand converters and its at 445 on a very safe tune but pulled 460 on a better tune but risky with the stock bottom end.probably going ahead with a bottom end rebuild or just leave it alone.
midlifeGT
9
cincinnati
Dec 23, 2010
  • Dec 23, 2010
I was contemplating the Kooks LT's and X-tube with converters as well. Then found that Kooks LT's and the Pypes brand sitting side by side look IDENTICAL for half the price. I mean IDENTICAL. Not one bend or weld or flange different between them. So I am still in turmoil on which way to go. I like the thought of having a cammy sound with the Detroit Rockers that Brenspeed now has available, but I also like the sound of the LT's with the high flow cats as well. Guess I will toss a coin come spring time.
G
gpp
137
  • Dec 24, 2010
i assume they are stainless steel and the flange is the same thickness.if so go for the pypes.
midlifeGT
9
cincinnati
Dec 27, 2010
  • Dec 27, 2010
Oh yes.
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
For Sale 2003 Cobra Redfire Convertible
  • SpectorV
  • Feb 20, 2019
5K
SN95 Mustangs For Sale (1994-04) Feb 20, 2019
SpectorV
