SuperCharger Help
  • Thread starter Thread starter 86_stang
  • Start date Start date Oct 17, 2005
86_stang
37
Annapolis. Maryland
Oct 17, 2005
  • Oct 17, 2005
I want to know what else i need to put on my motor to get ready to put on a s/c. I think all i need is bigger injectors i have 24 pounds right now. But look at my signature and let me know wha you think else i need also a reminder this is a stock 302 block which blower would be good for my set up already. Anything would help I am just stuck on what to do next. the s/c I have in mind is the procharger d2. Thanks
L
luckythirteen13
648
Anaheim, CA
Oct 17, 2005
  • Oct 17, 2005
what fuel pump are you running? with my vortech making 403rwhp i have 42# injectors, 255lph in tank pump and a t-rex in line pump.
what head gasket are you using? one meant for a sc motor is important. i also changed from head bolts to head studs when i got the sc.
get a dyno tune when its in. if you dont your asking for problems. if for some reason you dont want to, run an fmu till you get it tuned right
R
rflow50
172
TX
Oct 17, 2005
  • Oct 17, 2005
lucky13 is right, get some 42#injectors, a 255 fuel pump, and a tunning is very important, you may also want to put a main girdle. What kind of trick flow heads do you have, are they o-ring. I have a Vortech S-trim a i am very happy with it, but procharger is top sh???, expensive too, but if money is not an issue go for it.
86_stang
37
Annapolis. Maryland
Oct 17, 2005
  • Oct 17, 2005
I have the trick flow twisted wedge heads. But i guess I need to get bigger injectors then I got the fuel pump.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • Mindseye007
  • Aug 16, 2026
Mindseye007
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
