  • 1994 - 1995 Specific Tech
supercharger questions
  • Thread starter Thread starter 94gtslow
  • Start date Start date Oct 11, 2004
1 of 2 Next Last
9
94gtslow
401
Temple,Texas
Oct 11, 2004
  • Oct 11, 2004
can i run a blower with my 30# injectors?
And is it ok with p head since it raises the compresion?
can u run a blower with underdrive pulleys, not sure if mine are or not, car had a lost of mods when i bought it.
just looking on running blower or nitrous here soon, and trying to decide
ProKiller
3,064
15
78
PA
Oct 11, 2004
  • Oct 11, 2004
30#s are fine, i'm only running 24s. Vortech kits come with 24s, and a crank pulley, so u don't have to worry about the injectors, your fine. the underdrives don't matter, you get what u need from the kit. yes it will raise the compression, but the heads won't matter, its the pistons that make the difference. i would do a compression test to see what you have before you bolt on a blower. as long as your below 10:1 you should be good.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Oct 11, 2004
  • Oct 11, 2004
You guys are crazy with small injectors. Can't use the pulleys. Put the stockers back on.
Joes95GT
3,132
Delaware
Oct 11, 2004
  • Oct 11, 2004
Yahtzee!
How much does your motor mean to you? That should be the question.
Joe
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Oct 11, 2004
  • Oct 11, 2004
I dynoed an AFR of 13.5 with 30's and NO FMU and that was with AODE and stock heads/cam.
Repeat after me:
" 36 or 42
Unless you run an FMU"
Underdrive pulleys are OUT!
Fluidyne is IN!
RC
94TURBO5 O
2,509
VA
Oct 11, 2004
  • Oct 11, 2004
Exactly
Get the 42's with no FMU and def don't put on underdrive pullies.
9
94gtslow
401
Temple,Texas
Oct 11, 2004
  • Oct 11, 2004
so would i be with the 9.5 or so compresion and the 30#S?
what kinda numbers shuold i out down, or whats better the blower or the nitrous?
VibrantRedGT
424
154
Boca Raton, Florida
Oct 11, 2004
  • Oct 11, 2004
Engine compression has nothing to do with fuel pressure.
With a blower and 10psi probably 420HP or so. That's if tuned correctly on a dyno. I think you could keep the injectors you have now and occasionally spray a 100HP shot when needed. I would do the Nitrous.
Joe 5.0
1,184
Macomb, MI (metro detroit)
Oct 11, 2004
  • Oct 11, 2004
Prokiller said Vortech's kit comes with 24's, is that right? I was under the assumption that the FMU was designed to work the stock injectors.
I am contemplating a S-Trim purchase myself. Actually I've started putting away some $$ for it already.
9
94twinscrew
10
#10
  • Oct 12, 2004
  • #10
"Engine compression has nothing to do with fuel pressure.
Today 08:51 PM "............
Actually,it does.
10psi,and occasionally squirt a 100shot when needed??That would bring his stactic CR up to @18.5:1,...he would be lucky to be able to pull that one off with 42's,and a 255pump.The more boost that you throw at an enine,the more your compression ratio will increase.Higher Cr's need more fuel and less timing, to be able to avoid detonation.
30's will be fine as long as you have a good pump,and don't get too greedy with the boost. 8-10#s will be safe,...and a BTM would allow you run up to 14 or so.
P
ProCharge94
20+ Year Stangneter
Aug 31, 2004
71
Jax, FL
Oct 12, 2004
#11
  • Oct 12, 2004
  • #11
boosting your car will give you constant power that does not require you to fill a bottle. nitrous is great, but nasty in a mustang, especially with a large shot. 30lb injectors with a good pump and 10psi will run great. Instead of a FMU, just get a 1:1 boost ratio adjustable fuel pressure regulator.
Venom351R
4,548
41
98
MAINE
Oct 12, 2004
#12
  • Oct 12, 2004
  • #12
Im running #30's
Joes95GT
3,132
Delaware
Oct 12, 2004
#13
  • Oct 12, 2004
  • #13
94twinscrew said:
Actually,it does.
How do you figure the compression ratio will be 18.5:1? Compression is the ratio of volumes within the cylinder while the piston is at BDC and TDC. How would boost or nitrous bring the STATIC compression ratio up when compression ratios have nothing to do with induction style? If you want to get technical, how would it affect DYNAMIC compression? You let us know...
To the original poster - I'd go with nitrous if you've got the means to refill the bottles constantly. Richen up the car big time and sneak up on the tune. It would be very smart of you to get the car dyno tuned after whatever course of action you decide to take.
Joe
94TURBO5 O
2,509
VA
Oct 12, 2004
#14
  • Oct 12, 2004
  • #14
What are your goals?
450+ rwhp?
12's, 11's, 10's?
What's your budget $$$ wise?
ProKiller
3,064
15
78
PA
Oct 12, 2004
#15
  • Oct 12, 2004
  • #15
i got 390rwhp with 24# injectors with FMU. tuned. only running about 8lbs of boost. most boost, more fuel needed.
OT: joe, when u ran the 2.82" pulley how much boost were you seeing?
9
94gtslow
401
Temple,Texas
Oct 12, 2004
#16
  • Oct 12, 2004
  • #16
what is a BTM?
i have a 190 intake pump, dunno if thats good enough, or what comes with vortechs kit.
all im looking for is to run an 11.9-11.8 on good tires of course.
I dunno how much power, maybe 400 to the wheels, i dunno what it will put out, have no idea.
what is an fmu and what kind do i need if i need one at all.
9
94gtslow
401
Temple,Texas
Oct 12, 2004
#17
  • Oct 12, 2004
  • #17
hey prokiller its says on your site u got 460 rwhp is that with the 24#s?
P
ProCharge94
20+ Year Stangneter
Aug 31, 2004
71
Jax, FL
Oct 12, 2004
#18
  • Oct 12, 2004
  • #18
You do NOT need an FMU, an adjustable fuel pressure regulator has greater benefits. http://store.summitracing.com/defau...Ntk=KeywordSearch&Ntt=fuel+pressure+regulator
9
94gtslow
401
Temple,Texas
Oct 12, 2004
#19
  • Oct 12, 2004
  • #19
i have a fuel pressure regualtor already
plz reply
94TURBO5 O
2,509
VA
Oct 12, 2004
#20
  • Oct 12, 2004
  • #20
I bought my combo with just the S-Trim tuner kit, 42's, 255 FP, FPR and that was it. I added the PMS and methanol kit and hit 11.80's on Nitto DR's. I'm gonna try some slicks next time. I only got in 2 runs but I'm sure it's good for lower ET and I'm not a great driver either.
I'm still on stock internals, heads, fuel rails, cam, etc....just look at my sig.
1 of 2 Next Last
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
